Go to Post The point is that while having the abiltity to find information in a variety of reference sources is a useful skill, it does not replace a good, complete, fundamental knowledge of your subject material. - dlavery [more]
Unread 29-04-2011, 18:16
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
[FTC]: Edison Division replaying a ton of matches today.
Based upon what I saw on today's webcast, it appears as if the Edison division replayed about 10% of all qualification matches for reasons of unknown provenance.
My FTC team was asked to replay a match due to "excessive blocking," in the original match. This is completely absurd on its face in my mind. I'm curious what justification there might've been for replaying so many matches today and how they jive with what I typically expect from FRC -- that only a field fault warrants replaying a match.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 02-05-2011, 12:52
NalaTI NalaTI is offline
AKA: Alan
FTC #2848 (Techno Guards)
NalaTI is just really niceNalaTI is just really niceNalaTI is just really niceNalaTI is just really nice
Re: [FTC]: Edison Division replaying a ton of matches today.
The replays were almost always due to field faults. I heard there were WAY too many powerful wifi sources in the area and it really messed up the communications to the Samantha modules.
Unread 02-05-2011, 13:03
team F.T.C 4240's Avatar
team F.T.C 4240 team F.T.C 4240 is offline
Two cookies, one robot, all awesome
AKA: Derrick Maust
FTC #4240 (Techno Clovers)
Team Role: Driver
team F.T.C 4240 has a spectacular aura aboutteam F.T.C 4240 has a spectacular aura about
I started to wonder if it wasn't some of the robots and not just the field control, because we had no problems, even when the other 3 robots shut off in one of our matches we just kept going and it worked perfect so it might not be "just" the field control, also if you push the "mode" button on the controller it will disable the joysticks, making teams think that the robot is unresponsive, but you can still move the servo's. I hope that helped
~Derrick
"Like" us on Facebook to get info and updates on the team: http://www.facebook.com/FTCTechnoClovers
2008-09: MD Finalist Alliance Captain, MD Inspire Award Winner, Worlds Division Finalist.
2009-10: MD Winning Alliance Captain, MD Think Award Winner, OH Winning Alliance Captain.
2010-11: MD Finalist Alliance Captain, MD Innovate Award Winner, DE Winning Alliance Captain, Worlds Edison Division Finalist Alliance Captain.
2011-2012: MD Annapolis Qualifier Winning Alliance, PTC Design Winner.
DE State Inspire Award Winner.
MD State Winning Alliance Captain, PTC Design Winner.
World Championship Franklin Winning Alliance, Thanks Landroids and Cougar Robotics!
Unread 02-05-2011, 13:23
AKA: Alan
~Derrick
We also had no real problems except in two matches. The first was when all four robots lost communication for about 3 seconds, and the second was after they reset all the USB controllers and our arms person had the joystick pressed back so it thought zero was in the wrong place.
I definitely believe that most of the individual problems were robot related -- specifically the comms from NXT to motor/servo controller. Dick Swan (RobotC author) talked to us at our booth and we proved to him the RobotC bug relating to those communications and PID. I expect that there's another bug in there as well that's related to a similar firmware design problem. The connectors on the NXT are not really designed for this environment and that's an issue that has to be solved as well.
However, I do also believe that there were problems with the wifi network, and the combination of all of the above made it miserable for lots of teams.
Unread 02-05-2011, 13:44
AKA: Derrick Maust
Team Role: Driver
I agree, there are so many factors involved it almost can't be one problem, it might be some robots wired different, programing (we use labview), field control,Samantha, ect. So many things could have caused they shutting down of the robots. Like we had metal shavings in a sensor and that shut down our robot for about a week and it took a long time to find out why it kept reading 0 volts, so there is small things that can really mess up the robots, but if we share what broke/messed up our robot at practice and how to fix it then that can help other teams with the same problem and save a lot of time
Unread 02-05-2011, 14:26
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
I also think that it's interesting that some robots don't seem to have any field reset problems, wheras others seem to be fraught with them.
We caugt a problem during Software inspections that was caused directly be loose pins in the power switch connector. Looked like a coms failure, but it was reproducable by wiggling the wires... Squeezed the pins... problem gone.
I suspect the fasults are just compounding in some robots. For example, when I looked at the replay list (Cool mentor Max did a schedule for the replays), a couple of robots were in two replay matches... seems to indicate that the faults followed them. Coincidental that they were heavy defensive robots... that liked to hand out beatings to others?? Not conclusive... but it made me go Hmmmmm.
Phil.
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
Unread 02-05-2011, 14:35
l0jec l0jec is offline
l0jec has a spectacular aura aboutl0jec has a spectacular aura about
No matches were replayed which were not determined to be a field fault.
Yes, there were a few isolated instances of network issues, but the majority of the matches which were replayed were caused by USB issues (affecting the joysticks) on the FCS laptop on Edison field #2 Thursday morning.
As others have noted in this thread, the most common issues were robot related (NXT locked-up, Samantha connectivity to the NXT, or Samantha power issues). FIRST is aggressively looking into ways of better mitigating all of these issues (both field & robot related) in the future and the feedback the volunteers got from teams at the championship was extremely helpful.
Thanks for all the GP shown by teams and hopefully FIRST will be able to deliver a number of improvements for next season.
Hope this info helps.
Unread 03-05-2011, 12:07
ssi ssi is offline
AKA: David Spangler
FTC #2843 (Under the Son)
ssi will become famous soon enough
We also did not have any major field issues. Our issues dealt with RobotC. It seems to have a bug in communications with the motor and servo controllers. When this occurs, the NXT constantly tries to reset the motor and servo controllers. A symptom of the problem is that the external battery will register as off and you will no longer have control of the DC motors and servos. This can be a major problem if a motor is being driven at the time. This problem hit us a couple times in autonomous (we had built in a workaround in software for Teleop - we would cycle DC power on the bot via a LEGO motor) and cost us a match. Our battery was unplugged for the match after smoking a motor (and fused motor lead) at the end of autonomous.
Unread 03-05-2011, 19:47
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
Trapped under a pile of MECANUMS :P
AKA: @doctorfogarty
FTC #11444 (Garnet Squadron) & FRC#1102 (M'Aiken Magic)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
This comes from the words of John Tobes and Micheal Coleman.
There is a very consistent problem with NXT lock-ups which are always caused by static arcing.
Micheal was explaining to me FIRST was running some tests on a NXT lockup issue they have where the NXT completely freezes where there was no drop in voltage or Samantha module disconnect.
This happens when a 8000v~ or higher discharge occurs on the Tetrix Motor Controllers.
There was a discharge/ground cable that was given to us at championship and because it wasn't enforced both sides either using it or not experienced problems.
The people who did use it were at a high state of ground than the people who were not therefore when robots collided with the field or other robots that were charged all the energy was then discharged onto the grounded robot.
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
Mentor FRC Team 1102 M'Aiken Magic
"Head Bot Coach" FTC Team 11444 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
Unread 03-05-2011, 20:40
aklego aklego is offline
FTC #3595 (Schrödinger's Hat)
aklego is just really niceaklego is just really niceaklego is just really niceaklego is just really nice
This is VERY interesting. Do you, by chance, have any more information/photos of the ground cable?
let tau = 2pi
Unread 03-05-2011, 21:19
Shof Shof is offline
AKA: Shaun
Shof is a jewel in the roughShof is a jewel in the roughShof is a jewel in the rough
i too will like more info on this cable
Unread 03-05-2011, 21:30
Coach Doug Coach Doug is offline
FTC #3529
Coach Doug is an unknown quantity at this point
The ground cable was nothing more than a wire ( 18 gauge maybe? ) that grounded the chassis to ground ( bare wire on chassis and stripped/bare wire dragging on mat ).
I know from our robot we would get shocked during practice - i believe the theory was to help save samantha.
