Go to Post ps... it is better to have built a robot and lost than to ever played basketball at all - Andy Baker [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 04-06-2011, 05:25
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Re: Please help Wave Robotics earn $1,000!!!
Originally Posted by Andy Baker View Post
I would choose to help the team with 10 minutes of my time. In this case, I would feed the piggybank for 10 minutes. Then, I would get back to work.
Originally Posted by AlecMataloni View Post
Let's not forget the money you could've been making while you were planning and typing out immense tl;dr posts on Chief Delphi...
Tristian, you've got a point, but I think one post expressing your concerns would suffice.
Originally Posted by Tristan Lall View Post
(And yes, I am recognizing the irony of spending an inordinate amount of time discussing this topic, when perhaps I could be doing something more productive.)
Yeah, I know.1
I probably shouldn't have led off with a numerical example that begat more examples, as people objected to the simplifications in it. Gary actually made one of the underlying points quite effectively with his brief anecdote—which wasn't open to the same kind of argumentation, given that he was describing a real event.
In my defence though, all too often people don't want to run the numbers, because conventional wisdom can be so much more convenient. I'm glad I did, because it allowed me the chance to verify that my initial instinct was justifiable (at least to me). I'm absolutely not going to say that it's always worth it to spend time calculating things out or formally describing things like that, but when the consequences of making a faulty economic decision are significant, it's a useful technique to be aware of. (Legislators should try it more often....)
Originally Posted by lemiant View Post
It is for the current set (I only just found this thread), and it can handle about 3000 coins per minute. With only a rudimentary knowledge of python you could pull this off. You probably don't even need the headers, I just put them in so that if they store each request and all its information (which is very unlikely), they won't be able to detect the subterfuge.
If you were actually doing it for real, I don't think you'd want to leave consistent referrer metadata pointing to ChiefDelphi...that's like asking to get blacklisted (if they do indeed disapprove of scripted input).
EDIT: After reading through this thread I ran it again for the other side so as to not influence the outcome. Seriously though, you guys SIGNIFICANTLY underestimate the power and overestimate challenge of scripts. If two of me were fighting this out, the number would be in the tens to hundreds of millions (or, more likely, the site would crash).
Interesting that the rate at which you were able to submit was so high; I figured that because it was done through Flash, it actually had to completely execute all the animations before registering the next coin. I guess that was a shoddy assumption on my part. (Actually, from playing a lot of Flash games in the early 2000s, I should really know better.)
I still think this was at least significantly scripted, perhaps using a less-efficient technique, or perhaps running for less time.
1 My preceding posts in this thread run about 5 400 words, which is worth somewhere between 10 and 20 pages of text.
Unread 13-05-2011, 09:24
pwnageNick's Avatar
pwnageNick pwnageNick is offline
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
Rookie Year: 2007
pwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond repute
I left it at 357500-228247
Team 2949 hopes you guys get this!
FRC 2451: PWNAGE, Student/Team President (2009-2012)
FRC/VEX 2451: PWNAGE, Strategy/Design Mentor (2013-)
VEXU NAR: North American Robotics, Student/Chapter President (2013-)
Unread 13-05-2011, 09:35
Andrew Lawrence
Posts: n/a
Do they realize they're going against the CD community? A bunch of FIRSTers who spend a lot of time on the computer? I'm surprised no one has made a program that will autonomously search the page for coins, put them in the pig, and refresh the page and repeat! I think I've found yet another off-season project!
Unread 13-05-2011, 09:46
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Someone has made such a program (it's in post #35). But please don't use it; that would not be gracious.
Unread 13-05-2011, 10:22
Kimmeh's Avatar
Kimmeh Kimmeh is offline
Student at Kettering University
AKA: Kimberly
FRC #0068 (Truck Town Thunder)
Kimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond repute
Send a message via Yahoo to Kimmeh
To agree with Alan. It's not a gracious thing to do.
However, if you'd like to test your programming skills, Personally, I'd suggest trying to make one. Once you've gotten it done, don't use it other than just to test. Take pride in yourself that you managed to do it.
[2014 - Present] 68 Truck Town Thunder| Mentor |2014 - Great Lakes Bay Winner, Curie Quarterfinalists, District Chairman's Award, MCS Chairman's Award, Industrial Design Award, Entrepreneurship Award
[2014 - Present] 5046 Jacked Up Jackets| Mentor |
[2010 - 2013] 3421 Tachyon TECs| Mentor |2010 - Rookie Inspiration Award; 2013 - Coopertition Award , Kettering Quarterfinalists - 2nd Seed, Livonia Quarterfinalists - 2nd Seed Captain
[2009 - 2010] 2604 Metal and Soul| Student | 2010 - Gracious Professionalism Award, UL Industrial Safety Award
Unread 17-05-2011, 21:44
Techhexium Techhexium is offline
FTC #3555
Techhexium has a spectacular aura aboutTechhexium has a spectacular aura about
I think we're still doing good. I just helped dump in some coins. When I saw the counter raise by 1000, the school has only dropped about 550 coins.
Unread 22-05-2011, 11:58
Robotmmm Robotmmm is offline
Rookie Year: 2011
Robotmmm has a brilliant futureRobotmmm has a brilliant futureRobotmmm has a brilliant futureRobotmmm has a brilliant futureRobotmmm has a brilliant futureRobotmmm has a brilliant futureRobotmmm has a brilliant futureRobotmmm has a brilliant futureRobotmmm has a brilliant futureRobotmmm has a brilliant futureRobotmmm has a brilliant future
Closing in on a MILLION!!
If everyone throws a few coins in the pig we can cross that mark today!!
Unread 22-05-2011, 12:09
Borobo Borobo is offline
AKA: Patrick
FRC #0159 (Alpine Robotics)
Team Role: CAD
Rookie Year: 2010
Borobo is just really niceBorobo is just really niceBorobo is just really niceBorobo is just really niceBorobo is just really nice
lets break 1 million
only 85000 to go
Unread 22-05-2011, 19:06
Dancin103 Dancin103 is offline
The Crazy Blonde
AKA: Cassie
FRC #0103 (Cybersonics)
Rookie Year: 1997
Dancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond repute
Send a message via AIM to Dancin103
Re: lets break 1 million
I'm still voting! I love this fundraiser. I've been at it for an hour, it's a great thing to do while you're watching tv!
Cybersonics Technology Team 103
2003 Championship Chairman's Award Winners
NEED CHAIRMAN'S HELP?? Subscribe to our YouTube Channel, we answer your questions daily!
Unread 24-05-2011, 16:01
DonRotolo's Avatar
Back to humble
FRC #0832
1027424 versus 670797 at the moment.
