Go to Post The size of your team has nothing to do with the size of your heart. - Amanda Morrison [more]
Unread 05-05-2011, 01:13
NalaTI NalaTI is offline
AKA: Alan
FTC #2848 (Techno Guards)
NalaTI is just really niceNalaTI is just really niceNalaTI is just really niceNalaTI is just really nice
[FTC]: Our Robot
Since the season has now ended, we've put Alice (our robot) as a CAD file up on our website for anyone (anyone that has Pro/E) to look at and use any part. We'll also be posting all of our RobotC code as well.
You can find the Pro/E Backup file at:
http://www.technoguards.org/node/427
It is current as to what we used at World, where we were finalists for the Innovate, Design, and Inspire awards.
Enjoy!
Unread 13-05-2011, 12:10
electron's Avatar
electron electron is offline
Former Team Overdrive member
AKA: Joseph
FTC #2753 (Team Overdrive)
Rookie Year: 2010
electron is just really niceelectron is just really niceelectron is just really niceelectron is just really nice
Re: [FTC]: Our Robot
Sadly, I do not have Pro/E, and my outdated copy of Solidworks won't open the assembly, but I must say that, from the pictures posted on your website, it looks quite impressive! I wish I had an opportunity to see it in person!
I have two quite questions:
1. I notice that, on the mounts for what look like the bridge pressers, there is a connector on the "back" of the servo mount. What is that? I don't think it would be a bolt, and, unless you drilled out the hole, the tetrix axels do not fit in the smaller hole.
2. What was the purpose of the "stancing" as you call it? Is that how you adjust your baton dispenser's height?
I apologize if those questions are obvious in the CAD or from watching a match, but I was not able to do either.
Congrats on a great season, guys!
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
I may be one of the few people that has moved from FRC to FTC, and enjoyed it
Unread 13-05-2011, 14:42
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Rookie Year: 2007
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Can you guys make a .stp file of your assembly? I cant open it in Inventor without it creating a bunch of funny planes.
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 14-05-2011, 00:18
AKA: Alan
I've put a picture of the "hammers" for the bridge below. The only part that I can see that might be what you're talking about is the Tetrix Pivot Bearing (p/n W39093). We don't really like supporting anything on the servo shaft... it's plastic, so we try to do something for at least half of any potentially heavy object.
Several things. We do it to raise or lower the center of gravity. We OWN whatever space we are in (with the wheels at an angle we are impossible to push). We use it to push batons into the low goal when down. The back of the robot has a shelf that actually picks up and carries the rolling goal at the end game. It's cool...
I made the file and put it on the site. It may (or may not) be what you are looking for, if not, send me a note and I'll figure out how to export it better for you!
Unread 14-05-2011, 02:30
AKA: Andrew Remmers
Rookie Year: 2007
Thanks this should work, just incase you didn't know STP files most of the time are universal CAD files read by most CAD programs. I know making STP files in Pro-E is kind of funny but I'll download it when I'm on my windows partition tomorrow see if it works, If not you'll know!
- Andrew
Unread 14-05-2011, 12:11
AKA: Andrew Remmers
Rookie Year: 2007
Ummm Remember when I said Pro-E export was funny for .stp files? Well the file you have uploaded doesn't work. you might want to try enabling just surfaces (been awhile since I have had to do this myself and I currently don't ahve pro-e on this machine)
-Andrew
