Go to Post We may not have a robot yet, but we have Robot Potential! - Blue_Mist [more]
Unread 06-05-2011, 20:01
staplemonx's Avatar
staplemonx staplemonx is offline
The Idea Guy
AKA: JJ Biel-Goebel
FRC #1389 (The Body Electric)
Rookie Year: 2011
staplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond repute
chassis ideas swerve
I really liked how 1717 drove this year. So I am trying to improve on the chasis I saw this year with some guess work since i didn't get to really dive in and get to know it. pnuematic super shifter chain linked to drive shafts and window motor chain linked to drive collar. Electrical bay on the botom. 1/8 aluminum rivitied together. Assum the total chassis weight is 25lbs with rivits.
Is this about right?
Would you use banenot motors instead of window motors for steering?
Is the super shifter gear box over kill?
How much pushing power would this have?
How fast would this be with 2 or 4 cims?
ID:	10664  Click image for larger version
ID:	10665  Click image for larger version
crazy engineer
www.jjbiel-goebel.com
helping team 1389
http://team1389.com/
Unread 06-05-2011, 20:22
Aidan S.'s Avatar
Aidan S. Aidan S. is offline
2013 World Champions!
FRC #0610 (The Coyotes)
Aidan S. is just really niceAidan S. is just really niceAidan S. is just really niceAidan S. is just really nice
Re: chassis ideas swerve
I would not suggest using banebots on your steering. They have a tendency to short circuit and cause your robot to time out in matches for about 30 seconds. Putting them in the drivetrain would just worsen this problem because they would be exposed to a lot of debris, which is the cause of this problem. it's really easy to fix the shorts on the banebots, but they would be difficult to access in your drive system and you would have to fix the short every match because of the level of dirt and debris they would be exposed to.
2013 Galileo Division & World Champions with 1241 and 1477 #TheTheoryOfTexanCoyotes
2012 - ????: Mentor, Team 610 2009 - 2012: Student, Team 610
2013 - ????: Strategy Adviser, Team 1310
Thanks to all the great alliance partners through the years: 67, 188 x4, 191 x2, 488, 469, 578, 842, 862, 1212, 1241, 1305, 1310 x2, 1325, 1334, 1511, 1535, 1477, 1559 x2, 2122, 2168, 3161, 3360, 3396, 3476, 3609, 3756, 4124
Unread 06-05-2011, 21:23
R.C.'s Avatar
Happy Birthday! R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Not necessarily true. When you say banebots, what you do mean?
The gearboxes? The motors? The entire package?
The 2 main issues with banebots is:
-The gearbox blowing itself apart on high reductions (ex: 256:1)
-The 775 case shorting (not the 550/540/395)
-RC
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 06-05-2011, 21:46
Aidan S.'s Avatar
I was referring to the case shorts on the 775s. Our team experienced many problems with the 775s on our arm at our later competitions this year. Team 2056 showed us a method to fix the problem by attaching the positive battery lead to the positive terminal, and the negative lead to the case, and then moving our motor. That seemed to fix the problem, but it was still pretty consistent. The problem would be more apparent if the motor was on the drivetrain, which would be time consuming to fix after every match
Unread 06-05-2011, 22:21
rocknthehawk's Avatar
rocknthehawk rocknthehawk is offline
AKA: Aaron
FRC #1768 (Robo Chiefs)
rocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to behold
Everyone on 1717 was super nice about explaining their robot and actually showing us up close how it works. I was totally impressed!
Unread 06-05-2011, 23:38
11douglash 11douglash is offline
FRC #1072
11douglash is infamous around these parts11douglash is infamous around these parts
Stricly speaking, the maximum speed would vary upon any gearing / sprocket + chain ratios.
Unread 07-05-2011, 00:04
staplemonx's Avatar
The Idea Guy
AKA: JJ Biel-Goebel
Rookie Year: 2011
Makes sense. I was curious about a general 2 speed transmision. is swerve strictly for mobility + speed? Or can it get high torque and friction to the ground and push?
crazy engineer
helping team 1389
Unread 07-05-2011, 00:02
staplemonx's Avatar
The Idea Guy
AKA: JJ Biel-Goebel
Rookie Year: 2011
Thanks for the photos, are those pnuematic motors attached to the steering belts or the drive belts.
crazy engineer
helping team 1389
Unread 07-05-2011, 00:47
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
I talked to 1717 for a bit about how their drive train works. Until someone from their team posts, I will do my best to fill you in.
The pneumatic parts you see are for their shifters. They put the shifter mechanism on the opposite side of where the Andy-Marks are placed. I don't know the full story behind this but I have a hunch that they did this because originally they were going to have each CIM have its own gearbox and each module independently steered.
From my conversations with one of their mentors, they choose not to go that route to conserve two banebot motors. So they have two CIMs for each gearbox
So the belts you see by the pneumatics are for drive and the ones the cross are for steering. The drive left wheels together and right wheel together. For steering, the front right wheel is connected to the back left wheel and vice versa. This means to rotate the robot, they have to come to a stop but they specifically designed their robot to minimize the need to rotate.
For my opinion, you can get away with a standard andymark shifter. The supershifter has a extra gear reduction you don't need. You will defiantly want to use all 4 CIMs if you want to cover the field as fast as 1717 does.
Another great team to look up is 1640: wiki.team1640.com/
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 07-05-2011, 13:22
AKA: Aaron
From speaking to the mentors/students, the gearboxes were designed/built in house.
As explained, you can see the left side and right side are both powered from 2 cims each on a 2 speed gearbox. The two cross belts control steering between left front/right rear and vice versa.
Mark, could you explain why they would need to stop to rotate? From watching their matches on Curie, I never saw them really stop moving.
I haven't been able to find many videos, but you can see them here: http://www.youtube.com/watch?v=n63CaX1W-pU (the red alliance robot with the black lift)
(Team 126 is looking into building a similar drivetrain for the off season)
Unread 07-05-2011, 16:22
Head Mentor
To rotate their robot about its central vertical axis, they set each wheel to a 45 degree angle. I don't think they come to a dead stop before they start rotating. The nature of the turning procedure forces the robot to stop moving in the X and Y plane.
In this thread, I asked them to post more pictures of their 2010 robot.
http://www.chiefdelphi.com/forums/sh...ad.php?t=84838
Essential when rotating clockwise, let's say the right side drives forward and the left side reverses. Because the pivot action of the drive modules are actually connected front left to back right and vice versa, each sets rotate in opposite directions. Therefore the right side modules are actually facing opposition directions when rotating despite being driven from the same drive gearbox.
I hope this explains it, I finding hard to describe the motion. I have also observed that they engage the rotate motion very quickly and almost seamless with their driving. Perhaps this is due to their fast gearing in both drive and pivot.
Our team is also looking at 1717's drive train for next year, I think we will CAD it before we start asking ourselves if we actually have resources to pull it off. It would be competing against a new 6 wheel drive concept that emphasis on durability and ease of repair.
Unread 07-05-2011, 18:13
staplemonx's Avatar
The Idea Guy
AKA: JJ Biel-Goebel
Rookie Year: 2011
I follow you. To minimize the number od drive motors they crosslinked the drives as opposed to linking two wheels on one side so that they could rotate around center. 2 ways around this are 4 drive motors or a tank style turn with side wheels linked when you are ready to rotate.
That complicates things a bit. Now i could see why this drive gets heavy.
Going back to my incorect observation about pnuematic motors. Has anyone ever used them to control low torque rotation applications. This could be a way to have 4 individual drive motors while keeping the weight down.
Thanks
crazy engineer
helping team 1389
Unread 08-05-2011, 06:51
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Team Role: Coach
Rookie Year: 2007
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
As to the banebots vs. Window motors, we've actually used both to steer our swerves (windows in 2010, Banebots in 2011). We had a few problems with both, but the Banebots definitely served us better.
With the Window motors, running 1 per wheel module (#35 chain, 15T to 15T), we suffered from their incompatibility with Jags until we removed the locking pins. If you do this from the start (and personally, I'd avoid Jags unless you're CANing), you might be fine.
With the Banebots (RS-540s, 256:1 planetary gearbox), we never had a problem with the motor, but the gearboxes loosened up sometimes. This was likely simply a product of our mounting, since we stole 2 of the attachment points to mount it to the pivot. Great motors, but it's hard to give them up to the drivetrain in some cases.
Unread 13-05-2011, 01:34
Head Mentor
Well I am no expert at pneumatic motors.
I have contemplated using pneumatic motors since FIRST has open up the pneumatic rules. They appear to be not used for precision motion. Pneumatic valves, simply can't move fast enough.
If you found a pneumatic motor small enough to use on a first robot, perhaps it would be better to replace motors elsewhere so that you can use extra motors on the drivetrain. Maybe, rework a pneumatic screwdriver or grinder? That would make a pretty funny roller claw.
  #15   Spotlight this post!
Unread 07-05-2011, 00:06
staplemonx's Avatar
The Idea Guy
AKA: JJ Biel-Goebel
Rookie Year: 2011
Thanks for the heads up. Would the window motors work? Or should we go with pnuematic motors like 1717?
crazy engineer
helping team 1389
