Go to Post As I told my friend Joe Johnson, just because you aren't around as much doesn't mean that you can just close the book on this chapter, instead - just keep a book marker in this place, so you can remember how to find your way back home - when the time is right. - meaubry [more]
  #16   Spotlight this post!
Unread 10-05-2011, 22:48
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
Re: Omni Directional movement for tank drive.
the main goal of this is not to make the robot faster, it is to remove traction and torque from the factors that influence how difficult a robot is to push, thus allowing a team with single speed gearboxes to effectively block a team with 2 speed gearboxes.
  #17   Spotlight this post!
Unread 10-05-2011, 23:01
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Originally Posted by SamM View Post
Though your numbers are off by an order of magnitude or two
He forgot to divide 120 rpm by 60 to get 2 rev/sec
  #18   Spotlight this post!
Unread 10-05-2011, 23:45
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Curiosity:
How does this eliminate traction and torque as factors?
On traction:
A single speed robot CAN block a 2 speed robot.
Assume:
1. The single speed robot is oriented so that the motors do not backdrive when being pushed.
2. The tractive force between the robot and the surface is larger for the single speed robot than the two speed robot.
3. The two speed robot has enough torque to provide more force than the frictional force provided by the wheels and "spin" the wheels/tires.
The frictional force between the robots contact surface (ussualy wheels/treads) is what keeps it from being pushed. For the most part, in FRC, any robot with AM tread can be an effective "blocker".
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
  #19   Spotlight this post!
Unread 11-05-2011, 00:20
AKA: Isaak
Team Role: CAD
in my experience teams that attempt to block sideways are easily "spun" also AM tread is not even close to the grippiest material used, the blue mcmaster tread is much gripper.
  #20   Spotlight this post!
Unread 11-05-2011, 14:38
SamM SamM is offline
FRC #5842 (Royal Robotics)
Team Role: Teacher
SamM is just really niceSamM is just really niceSamM is just really niceSamM is just really niceSamM is just really nice
If you watch videos of meltys (google: spinning tortoise), you'll note as soon as they contact something they bounce away in the opposite direction. All the offensive robot would have to do is bump into the melty, and the reaction force would move it back and to the side. The offensive robot would move back a little but much less because it has much better traction.
I admit it would be cool to see, but i don't see it being a viable design for FIRST.
"The universe is probably littered with the one-planet graves of cultures which made the sensible economic decision that there's no good reason to go into space--each discovered, studied, and remembered by the ones who made the irrational decision." -Randall Munroe, XKCD
  #21   Spotlight this post!
Unread 11-05-2011, 23:31
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Team Role: Coach
Doug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond repute
This reminds me of Kingman's (FRC# 60) 2002 robot. It could pick up two 180 lb goals and spin them around a center turret. While they never used it during competition, I saw them demo it for a TV crew at SVR that year. It is one of the most impressive and scariest things I've seen a robot do.
Work Hard, Have Fun, Make a Difference!
  #22   Spotlight this post!
Unread 12-05-2011, 10:40
stundt1's Avatar
stundt1 stundt1 is offline
Steve
FRC #4930 (Electric Mayhem)
stundt1 will become famous soon enoughstundt1 will become famous soon enough
Originally Posted by Grim Tuesday View Post
Our team has a running joke of inventing "mecanum treads".
Hehe we made some last summer a prototype.
