Go to Post I can't believe that I said the CD community could be patient - in December. - JaneYoung [more]
Unread 08-05-2011, 22:29
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
3 motor gearbox
I was wondering what factors to take into consideration when designing a gearbox for 2 CIMS and 1 FP. Obviously reduction off of the output shaft for the motor needs to have a matching RPM, but is there anything else?
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 08-05-2011, 23:33
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
Re: 3 motor gearbox
You can add the power of the motors in each gearbox. Power is absolute and additive and if you know the relationship between power, torque and speed (P=T*n (with proper units/conversions)) you can define all of the characteristics of your motors in your gearbox. Your power will remain the same as you match output speeds of your motors but your output torque will go up by the same factor that your RPMs fall.
If you look through the CD white papers you can find a topic on 'traction limited' drive trains and what maximum gear ratio can be used so that you don't trip breakers and your wheels don't slip. It suggests finding the power of your motors at a maximum 40 amps of current draw so that you stay within the limits of your circuit breakers.
As far as max speed and max acceleration go, that is something I have been working to understanding myself and I have a spread sheet made up for my own understanding of the topic. Maybe that topic can be answered by someone wiser than I.
JVN's drive-train calculator is also very nice and I recommend it for quick design checks, but it can be a little bit of trouble when you start mixing motor inputs. I wanted to see how the numbers worked so I did my own math and checked it with JVN with mixed results based on my own design assumptions.
Unread 08-05-2011, 23:41
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
Re: 3 motor gearbox
I've got the math behind how it will work down, I'm interested more in the construction aspect.
What motor characteristics need to align to pull off a gearbox with different motors?
Unread 08-05-2011, 23:54
A_Reed's Avatar
Lead Design Mentor
AKA: Adam Reed
Re: 3 motor gearbox
If that's the case then all you have to worry about is matching speeds with the CIMs (whether COTS or custom) and mounting it with proper alignment to gear central to your other two CIMs. That comes down to simple geometry in CAD.
The one thing you are going to have to double check is the added torque and bending stresses to your shafts from the extra motors. What may have been overkill for 1-2 CIMs may be verging on 'just enough' for the added power. Diameters may have to be increased to maintain a reliable factor of safety on par with the standards set up by common designs and COTS items. Your stresses may check out and look very safe but for alignment and efficiency in spur gears it is better to design for deflections.
Unread 09-05-2011, 00:08
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
Re: 3 motor gearbox
The rs-775 is about 3x faster than CIMS, so should it's gear be about three times bigger? I'll do the math to get it exact if this is the case, but it seems like the CIMulator is the way to go.
Unread 09-05-2011, 00:17
Chris is me's Avatar
AKA: Pinecone
Re: 3 motor gearbox
The opposite. Should be three times smaller.
of course, you can't go three times smaller than 12 teeth, hence why CIMulators or other banebots gearboxes are used for an initial reduction.
Unread 09-05-2011, 00:21
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
Re: 3 motor gearbox
Right, that one. I've been studying for my physics AP tests and my brain is fried.
Unread 09-05-2011, 08:28
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Re: 3 motor gearbox
Just be careful running 4 CIMs and 2 RS-775s in one drivetrain. They draw a LOT of electrical power at stall (enough to brown out a cRIO from time to time - hopefully the cRIO-FRC2 will fix this with its 9V minimum supply voltage). Design your gear ratio appropriately.
A_Reed's Avatar
Lead Design Mentor
AKA: Adam Reed
Re: 3 motor gearbox
The CIMulator should work well enough to match speeds.
One thing I have found is that a 775 maxed out @40 amps has the same power output as a CIM @40 amps, although I don't know how many 40A breakers one can use. So the 775 may not be fully understood as far as reliability quite yet but looks as if it is on par with a CIM in power.
Unread 09-05-2011, 09:59
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
Re: 3 motor gearbox
What do the green boxes in the excel document mean? Is that the recommended gear ratio?
Unread 09-05-2011, 10:15
A_Reed's Avatar
Lead Design Mentor
AKA: Adam Reed
Re: 3 motor gearbox
Sorry I didn't make a distinction between inputs and outputs, both are green. The min ratio was found for the time to cover 54 ft, the max ratio is based on 40A traction limited specs including CoF and the last three were found by finding where the ratio/max torque and ratio/max speed curves are equal. My math my be a little off on some of the numbers and the intersections are based on those numbers. All numbers have efficiencies accounted for, that is what the 'gear stages' input is for.
Unread 09-05-2011, 10:27
A_Reed's Avatar
Lead Design Mentor
AKA: Adam Reed
Re: 3 motor gearbox
Wow, that's awesome! Is everything dependent such that I can change variables?
Yes, your inputs on each page are Speed (ft/s) (don't need to modify that one as you are matching to that speed anyways), Torque (ft-lb) (Pulled from motor spec pages, taken for one wheel), Coefficient of friction, Wheel Dia. (in) and Gear stages. The Min Time is pulled from the 'T54 ft.' column and you have to follow that to look up the min ratio.
*The speed conversion isn't mathematically linked to the wheel dia. cell and you may want to modify the equation in that cell to reflect that change*[edit]
Unread 09-05-2011, 10:40
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
Re: 3 motor gearbox
Increasing the wheel diameter increases time. Is this right, because at first glance it seems backward?
Unread 09-05-2011, 11:56
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: 3 motor gearbox
It's a balancing act of more acceleration time vs. more time at max speed. In some cases going to a larger wheel, with no other changes, will indeed cause a higher time.
It appears to be simulating each side as if the 1 side powered the entire robot going forward, and only 1 CIM is ever used on the 3 tabs. It this intentional? Other than that it looks pretty good.
Though I would caution -- if you replay your matches this year, even on an 'open field' like this year, how far did your robot ever sprint in a straight line? Might be best to optimize it for a distance based upon your strategy (20-40ft for us)
GitHub
  #15   Spotlight this post!
Unread 09-05-2011, 19:43
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: 3 motor gearbox
Anybody have any data on how long a 775 will withstand 40 amps before smoking?
