Thread Tools |
Rating:
Display Modes |
Re: Bill's Blog, 5/11/11 "Wait, Did he say pool"
If you make the autonomous mode extraordinarily important, more people do auton. Just give it more points and let incentives do their work!
Too strong of an incentive and any team that can't get an auto to work suddenly is completely not competitive.
and if autonomous is more important, that gives us more motivation to get the robot put together in 5 weeks rather than 6. But it also gives us more motivation to build a "practice bot" and spend 4 months in build/program mode...which some teams do already. I kinda like a break after 6 weeks.
Yet probably less than 50% of teams could reliably score in autonomous. |
The problem the GDC has is making a game that is good for both week 1 regionals and the championship. This year's game was good for early weeks, but pretty boring at the championship (the diminishing value of tubes, imo, really killed the game when played at the highest level). A longer auto would be good later in the season (pinks 3 uber auto, more 5 ball auto in Breakaway), but would be awful watching 6 robots stand still for 40 seconds week 1. |
I loved the "end early for bonus points" element of Diabolical Dynamics, and since then, I've always thought dynamic lengths of periods would be an interesting game feature. For example, a 10 second auto, which gets extended to 30 seconds if the robots accomplish a certain task. Or a long autonomous, where the first robot to accomplish a task gets switched to teleop early, while their opponents remain in autonomous for a while longer. If done right, it could give top notch programmers a chance to really shine, while reducing the "boredom factor" from 6 robots that sit still autonomously.
I've got a better idea...
Standard FRC match cycle is six minutes, start to start--that means that, in a 2:15 match, the field is hot only 37.5% of the time. If those matches went to three full minutes, and the match cycle expanded to seven minutes, then the hot-field percentage goes to 42.9%. 3:15 and seven-minute cycle? 46.4%. For the same amount of time spent doing load-out, reset, load-in, and introductions, you get that much more time of the game being played. Robot wouldn't run for that long, you say? Imagine if your matches were three minutes, but your robot only ran for two minutes. Just like the real world, you can't run your machinery around the clock--maintenance, repair, slow business, constraints on supply from upstream, operator rest periods, and so on all conspire to limit how much a piece of machinery can actually run. So with a time limit on each robot, you now have an additional layer of coordination necessary to achieve game objectives. It wouldn't work for all games--Lunacy would be awful with this scenario--but it could afford FIRST some flexibility in scheduling (or even some other objectives; imagine if robots above 110 pounds had a one-second delay in activation in the middle of the match.) |
I do agree with your notion of the tubes becoming less important as the minibots became more prevalent, though. |
#11
Having said that...I've wanted a longer autonomous for years. A variable length auto is a cool idea, if it has the right incentives. And as long as the auto has a piece that has some points (even if a small number) for driving a pretty straight-forward pattern (say, straight ahead) there should be very few teams that can't get *something* working. |
#12
