Re: Mecanum Wheels
nice photo. Did you use ball, roller, or journal bearings for the rollers? Can't tell from the photo. |
Re: Mecanum Wheels
Re: Mecanum Wheels
Re: Mecanum Wheels
Yes but with that said the coefficient of friction between the neoprene and the hard fiber washer is greater than that of the hard fiber washer and the aluminium hub so there is just about no rotation of the washer relative to the roller. I hope that make sense. If I was to remake them i would have done it more like how 357 did it this past year with a nylon core and a molded urethane rubber outside.
Re: Mecanum Wheels
Minimizing axial free-play also minimizes losses. How did you determine the roller profile? |
Re: Mecanum Wheels
When was the last time you saw a mecanum robot going 18ft/s(?), and then stop in less than 5ft? |
Re: Mecanum Wheels
http://www.fingertechrobotics.com/pr...mecanum-set-hg
what if instead of using 4 6 inch mechs, you used 8 or even 12 of those. that would greatly decrease the amount of rotational inertia in the wheels, those little wheels are also higher quality. |
Re: Mecanum Wheels
Re: Mecanum Wheels
i was actualy thinking of mounting all 3 right next to each other on a standard frame setup. i would probably use #25 chain directly driven from a cim ( no gearbox)
#10
Re: Mecanum Wheels
Such being the case, a correct inverse kinematic translation would require that each of the 3 wheels in a set be driven at slightly different speeds. If you just chain them together and drive all 3 at the same speed, you'll get some scrubbing of the contact patch which means additional loss of power and traction. |
#11
Re: Mecanum Wheels
i think that the same thing would happen if the were mounted co-axially. while it is true that while using all 3 degrees of freedom there would be some scrub, during normal translation there would be none, conceptually it is 3 entirely separate mechanum bases, driving in the same space, at the same speed.
#12
Re: Mecanum Wheels
Re: Mecanum Wheels
assuming constant deceleration a = (V*V)/(2*x) = (18*18)/(2*5) ~ 32 f/s/s ~ 1g ... so you'd need an effective CoF of 1. To get that with mec, you'd need about 1.4 CoF between the tread material and the carpet. So you'd have to make your own custom rollers with high-traction tread. |
#14
Re: Mecanum Wheels
There aren't exactly a lot of sources of mecanum wheels in the FRC size range. AndyMark is the biggest (and to some extent, the only) one.
You may want to get in touch with 357 (or, the Behind the Design books from the 2006 and 2007 FRC seasons); they've got casting their own down to a fine art. Or, if you can find someone who can build them directly with a direct manufacturing machine, that might do it. Just watch out for FRC cost rules--the material can get pretty expensive. Matt, offseason is the best time to do mecanum. Not during the season. 330 spent 2 offseasons prototyping a set before giving them a chance to make a competition robot in the build season. |
