Go to Post Celebrate your failures as well as your successes. - Taylor [more]
Unread 15-05-2011, 13:41
JamesTerm's Avatar
JamesTerm JamesTerm is offline
Terminator
AKA: James Killian
FRC #3481 (Bronc Botz)
Rookie Year: 2010
JamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to behold
Lightbulb Solution to fix wind river if it locks up during build!
Greetings c++ programmers,
I recently encountered a bug where I was making a build and during the build I received a BSOD (blue screen of death). I then restart machine and find that when I build, it no longer built and it would lock up during compile. I tried just about everything from cleaning my solution to reimaging wind river, and still the same problem! I finally used process monitor to see what file(s) it was trying to read and it was reading only one file here: C:\Users\James\AppData\Local\Temp\wrs_licProxy.Jam es_Machine
Once I deleted this file and tried it... voila! It now works again!
I am not sure how likely this will happen for other people, but if it does I hope they find this post so they don't lose hours of hair pulling as I did.
