Go to Post I can't wait to be one of those old kids who can say "Yeah, I remember the days before districts." and then watch the kid's eyes widen when I explain the days of regionals.. - rachelholladay [more]
  #31   Spotlight this post!
Unread 18-05-2011, 16:49
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Better Batteries for Driver Practice
Originally Posted by akoscielski3 View Post
How are the chargers not competition legal ??
In prior years, there was a rule that would have fallen between <R34> and <R35> in section 4 of the 2011 game manual. Here is 2009's <R39>:
An automatic battery charger rated for a maximum of 6 amperes must be used to charge the ES17-12 batteries. When recharging the ES17-12 batteries, either the charger provided by FIRST or an automatic charger with an equivalent charging current rating may be used.
The rule was not present this year. Even without a rule specifying so, it's still wise to use automatic chargers that don't exceed 6 amps.
  #32   Spotlight this post!
Unread 18-05-2011, 18:43
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Re: Better Battaries for Driver Pratice
Originally Posted by Al Skierkiewicz View Post
OK,
Let's get some info straight here and in one place.
1. Our batteries are specified by the manufacturer to be charged at 6 amps or less. Battery life can be significantly increased when charged at 1/10 C or about 2 amps.
2. Life is significantly reduced by heavy loads like an FRC robot drawing currents in excess of 200 amps over a two minute match.
3. Charging at high current on our batteries causes internal heating and the possibility of out-gassing and case failure if the vents do not operate.
4. Our batteries are AGM types and the plates within the cells are not as robust as older technology lead-acid batteries.
5. Excessive heat within the battery causes the plates to deform, leading to internal shorts and a variety of other issues leading to lower battery life.
6. Hot batteries during charge can fool many/most smart chargers into producing damaging voltage/current during the charge cycle.
7. AGM batteries are nothing like NiMH, NiCd, LiPO, Li ION or other types and each requires a specific type of charger. Do not mix chargers and battery types.
Thanks for the clarification. Now I know. Although our team does NOT charge them at 15 or 10 amps, so we should not have a problem with any of this
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
