Go to Post For every hour you spend screwing pieces of your robot together, 20 hours of important stuff goes on behind your back. - Eric Bareiss [more]
Unread 18-05-2011, 21:40
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
mwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond repute
Re: How to go about making tankDrive and ArcadeDrive methods
Originally Posted by kinganu123 View Post
That doesnt work for moving the joystick to the corners or towards them. thats the hardest part of arcade and ive been trying a bunch of algorithims but none of them can be used for more than one specific coordinate
well you could do an if > 1 output 1
or a divide by 2
those should work somewhat.
the best case would be to use trig even for an arcade drive to ensure max values
"Never let your schooling interfere with your education" -Mark Twain
Unread 19-05-2011, 00:00
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Look at this diagram, and see if you can figure out what the left and right motor speeds should be for the red, green, and blue dots. If you can do that, you should be able to design an algorithm to compute the wheel speeds for any joystick position.
Some drivers find this behavior more intuitive.
Name:	reverse arcade.png
Unread 19-05-2011, 20:33
Ether's Avatar
Rookie Year: 1969
What do you mean by "doesn't work" and "one specific coordinate" ? Please post a couple of example calculations to illustrate the problem you are encountering.
Unread 18-05-2011, 19:29
Ether's Avatar
Rookie Year: 1969
Originally Posted by lineskier View Post
programming a mec via trig is a lot easier than doing it without it,
FR = -Y - X -Z
FL = -Y +X +Z
RR = -Y +X -Z
RL = -Y -X +Z
How does trig make the above any easier ?
for scaling reasons i'd leave out rotation at first.
Scaling is straightforward. Find the max absolute value of the 4 wheel speed commands above. If that max value exceeds the max command you want to send, then divide all 4 wheelspeeds by it.
