Go to Post I have never before seen the words "smaller" and "Saturn V" used in the same sentence. Wow. :yikes: - DonRotolo [more]
Unread 19-05-2011, 22:52
vincentkee vincentkee is offline
FRC #0687
vincentkee is an unknown quantity at this point
4" vs. 6" + 8" Diameter Wheels
I've noticed a lot of the veteran teams used the 4" diameter wheels in their 6WD or 8WD drive systems.
Is there any significant advantage to using them over the larger 6" or 8" diameter wheels?
And is there any significant advantage to implementing a 8WD instead of a 6WD?
Unread 19-05-2011, 22:57
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Re: 4" vs. 6" + 8" Diameter Wheels
4" wheels allow you to create a longer wheelbase, since the smaller wheel allows the axles to be spaced apart further.
Additionally, 4" wheels reduce the reduction required from a CIM motor to achieve a reasonable speed. Smaller reductions mean less frictional loss.
They arguably produce faster acceleration, since the wheels have less rotational inertia.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 19-05-2011, 23:04
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
In addition to what Joe posted above they are also lighter and tend to result in a chassis with a slightly lower Center of Gravity.
Unread 19-05-2011, 23:11
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
i really like small wheels, but i like 5 or 6 inch wheels the best. they are large enough to raise the ground clearance above what a 4 inch wheel set would give.
Unread 19-05-2011, 23:17
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
What for? Is there any reason you needed more than ~5." of ground clearance this year?
Unread 19-05-2011, 23:21
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
See this post I made in another thread for why we like small wheels.
http://www.chiefdelphi.com/forums/sh...6&postcount=74
In 2010 we climbed the bump with 4" wheels.
Unread 19-05-2011, 23:33
AKA: Isaak
Team Role: CAD
i would prefer 5 inch wheels, but settle for 6 inch wheels for several reasons. most of the omni wheels from andymark smaller than 6 inches are very bumpy, also 4 inch mechanums don't exist for FRC. i think 6 inch wheels are the most versatile, and that the tiny benefit of going to 4 inch wheels is not worth the flexibility trade-off.
Unread 19-05-2011, 23:35
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
When do you ever design a drivetrain for both mecanum and regular wheels? There's flexibility, and then there's being a jack-of-all-trades, master of none.
Unread 19-05-2011, 23:51
AKA: Isaak
Team Role: CAD
one reason is nonadrive or octomanium or any other number of names for the same basic mechanical idea, the drives usually use 6 inch mechs and 6 inch traction wheels. i prefer to use a very standard, modular design strategy, with multiple options. there are many more options for 6 inch wheels than any other wheel set. closon, andymark, pneumatic, good omni wheels, mechanum. with 4 inch wheels many of these types of wheels must be custom made. the 6 inch wheel size is the most versatile. and while it is true that some sacrifice is made in order to gain this flexibility, it is such a small advantage that it doesn't really impact performance too much.
I already designed a frame that will accommodate any drive-train. one of the sacrifices of that frame, was giving up 4 inch wheels of any type.
Unread 19-05-2011, 23:58
Smaller wheels in octocanums make desired reductions easier to produce.
Unread 19-05-2011, 23:47
Even when two are paired together?
You can get a smooth ride with omnis...
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
The 4" dualie omnis on 2175's robot this year gave a smoother ride than 6" omnis we have used in the past IMO. Admittedly they are a bit heavier and are more expensive than a single 6" omni, but the weight and cost both typically are gained back by knocking out a stage of reduction.
Unread 20-05-2011, 00:03
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Does anybody have mass and moment of inertia data for comparable 4", 6", and 8" wheels?
Unread 20-05-2011, 03:14
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Wouldn't this vary somewhat significantly based on the material of the wheel as well as any lightening? I'm sure we could calculate worst case scenarios (solid wheel of aluminum billet) but I'm not sure it would actually be terribly useful. Perhaps assign real materials to the AM plaction/performance wheels and use your CAD program of choice to computer the moments?
  #15   Spotlight this post!
Unread 20-05-2011, 09:29
Ether's Avatar
Rookie Year: 1969
Yes, of course. That's why I said "comparable" in my post. Compare a 6" wheel that you would make for your robot to a 4" wheel that you would make for the same robot.
Originally Posted by Tristan Lall View Post
(I say roughly, because the different sizes aren't scaled versions of each other; some things, like hub size and rim thickness, tend to be driven to a large degree by other design constraints.)
Exactly. That's why I said "comparable" :-)
