Go to Post "We put the eek in Geek" - Wayne Doenges [more]
Unread 23-05-2011, 11:38
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Belt vs. Chain
Originally Posted by lemiant View Post
Ok, so I read 234s paper, and it pretty unequivocally states that belts are better. How come everyone still uses chain?
The reasons were right there in the paper:
  • Belt requires a more integrated design and precise manufacturing
  • Wheels and belt must be assembled concurrently, unlike chain
  • Belt requires more physical space because of the width differences for varying load capacities
  • Chain drive is a known, proven system for transfer of power from the drive motors / transmissions to the drive wheels and between the wheels
Unread 23-05-2011, 12:05
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
Team Role: Leadership
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Re: Belt vs. Chain
I doubt 1 & 2 would be insurmountable for a team like 1114 (who I happen to know uses #25 chain), or 228. I'm not sure about #3, how much extra space are we talking here. And #4 has never scared a powerhouse out of doing anything.
Unread 23-05-2011, 12:15
Ether's Avatar
Rookie Year: 1969
Re: Belt vs. Chain
I doubt 1 & 2 would be insurmountable for a team like 1114 (who I happen to know uses #25 chain)...
You didn't ask if re-engineering their process to use belts would be an insurmountable task for a powerhouse team like 1114.
...And #4 has never scared a powerhouse out of doing anything.
It's not a question of being scared. Experienced successful teams generally allocate their limited resources to tasks that have the greatest benefit/cost ratio.
Unread 23-05-2011, 12:30
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Belt vs. Chain
The difference in belts versus chains, as others have mentioned here and as our team has experienced, is really one of time. Using belts typically takes more time, as you need to work our more precise distances, figure out precise lengths of belt to order, etc. Chain is quick and easy - you can get a kitbot assembled in a day with a chain drive. For a belt drive, unless you have the exact length of belt on hand, it'll take longer (lead time on ordering new belts).
We've always used chain on our drive system. It's quick, easy, and reliable (we've never had much of a problem with it). We've used belts in some other places as well - most notably in our claw/roller assembly this year and in our shooting turret for Lunacy. In both cases, we had to obtain belts of the appropriate length, and build in tension adjustment (this year, mounting the Banebots motors in slots for adjustment, for Lunacy we mounted CIM motors on rotatable armatures). Both of those tension adjustments were set and forget... but they needed to be planned out ahead of time. Contrast that with our drive system this year, where we through it together and added tensioners after the fact.
As we've told our team countless times... there are a multitude of ways to solve any one problem, and many of those ways are going to provide equivalent results.Chain versus belts is one of those comparisons... they'll both give you the same results, it's really a decision on what you would rather do, and where you want to spend your time.
Unread 23-05-2011, 12:43
lemiant's Avatar
the Dreamer
AKA: Alex
Re: Belt vs. Chain
I would just think that with a 10% performance gain, some of the big teams would have put in the time to work it out.
Unread 23-05-2011, 12:53
Ether's Avatar
Rookie Year: 1969
Re: Belt vs. Chain
You have to ask yourself the question, "10% of what?".
When you're talking about teams like 1114, they probably already have a drivetrain that more than meets their needs.
If the day ever comes that they believe they could gain a competitive advantage by allocating resources to re-engineer their drivetrain, I'm sure they will consider doing that.
Unread 23-05-2011, 13:01
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: Belt vs. Chain
We've considered belts in out drivetrain, but have always turned them down for a few reasons.
Currently, we almost exclusively use chain; we know chain, we have lots of sprockets, no pre-planning required to chain something up. With belts, we now have an entirely separate set of parts that need to be identified, purchases etc...
The disassembly is a huge disadvantage too. We've never lost a chain on our drive, but if need be we could replace one in under a minute. Switching to belts requires a redesign of our gearboxes, or partial disassembly of a gearbox to install a spare.
Unread 23-05-2011, 22:35
emekablue's Avatar
emekablue emekablue is offline
AKA: Eunice
FRC #1671 (Buchanan Bird Brains)
Rookie Year: 2010
emekablue is a jewel in the roughemekablue is a jewel in the roughemekablue is a jewel in the rough
Re: Belt vs. Chain
What about belts being used not for the drive, but for the arm. We have had quite the problem with tensioning our arm's chain (other tensioners are too large, and we have about an inch of slack), I think because we are over-torquing the motor. Will putting in belts help solve this problem? Or will a simple change in gear ratio do the trick?
Unread 23-05-2011, 23:03
lemiant's Avatar
the Dreamer
AKA: Alex
Re: Belt vs. Chain
Correct me if I missed something, but couldn't you just remove the extra links?
Unread 24-05-2011, 00:50
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Rookie Year: 2010
slijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to behold
Re: Belt vs. Chain
You should start by removing the extra links, as lemiant pointed out. Chain tensioners are to be added when you can't remove links any more.
Furthermore, changing between belts and chain does not change the load on the motor. Adding countering forces, such as springs or gas shocks are the kinds of things you want to add to reduce torque on the motor.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 24-05-2011, 01:56
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Re: Belt vs. Chain
Belts definitely won't help. Shorten the chain and use some counterbalancing to take load off the chain, either surgical tubing or gas strut.
Mentor 2415
Unread 25-05-2011, 02:03
emekablue's Avatar
AKA: Eunice
Rookie Year: 2010
Re: Belt vs. Chain
We did both of that probably during week 6. However we used bungee cords as our counter.
Unread 23-05-2011, 13:32
Unsung FIRST Hero
Karthik Karthik is offline
VEX Robotics GDC Chairman
Rookie Year: 1998
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Re: Belt vs. Chain
We've often talked about moving from chain to belts for our drivetrain. Most of our reasons for not making the switch have already been mentioned, but there's one big one missing, which is very specific to FRC. The lead time on the exact belts and sprockets we would want, imported into Canada, is about 2 weeks. We used belts on our elevator and roller claw this year, and acquiring the belts was the largest bottleneck. There's no way we'd sacrifice that much programming, practice and systems integration time on our drivetrain, for the marginal benefit that belts provide. Now, if we could find a way to reduce these lead times, belts would become a very attractive option.
Hardly. Number four keeps us from doing things all the time. We'll always take a solution that we know works 100% of the time over a solution where we have less confidence. Reliability is one of the keys to a successful FIRST season. We will not give it up for a new solution until we've proven the new solution is just as reliable as the established one.
As our founding mentor Stephen Rourke used to say, "The most effective solution is the simplest one that works".
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 23-05-2011, 12:23
Andrew Schreiber Andrew Schreiber is offline
Joining the 900 Meme Team
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Re: Belt vs. Chain
Use what you know and don't fix what ain't broken.
  #15   Spotlight this post!
Unread 23-05-2011, 12:36
Re: Belt vs. Chain
OR try some set ups out in the offseason!
