Go to Post Dean Kamen, you deserve a cookie. - Jessica Boucher [more]
Unread 27-05-2011, 11:43
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Limitting motor torque
Originally Posted by Jared341 View Post
What is truly insidious is that a hot motor is less efficient than a cool one - resistivity in metals increases with temperature.
In addition to increasing the electrical resistance of the motor's coils, the heat also affects the motor's magnetic properties.
Unread 27-05-2011, 13:07
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
we put mountain dew cans over our cims, at first because it looked cool, but i think it did help with cooling. the cims in this years robot never seemed quite as hot as previous drive's.
Unread 27-05-2011, 13:14
Ether's Avatar
Rookie Year: 1969
Unless the dew cans were adorned with fins, I can't see why it should help with cooling. Black is a better radiator.
Unread 26-05-2011, 16:15
JamesBrown JamesBrown is offline
Back after 4 years off
FRC #5279
JamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond repute
increasing friction will increase the amount of power draw when the robot stalls. however that is not a bad thing, more grip = more pushing power. because the robots only run for 3 min at most, power draw, and efficiency dont really matter.
I have seen robots that drain a battery in one match, power draw is something teams should think about.
Increasing friction also increases the amount of power that is required to turn, this can result in a large power draw. If there is a reasonable amount of performance increase that can be gained by minimizing slipping in software why not take advantage of it?
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
