Go to Post We are just helping to keep Home Depot from going Bankrupt :D . - E. Wood [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 05-31-2011, 12:00 AM
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
Team Role: Leadership
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Project Wide Parameters
Is it possible to create a parameter which exists in all the part files in a project?
Unread 05-31-2011, 12:23 AM
SavtaKenneth SavtaKenneth is offline
AKA: Yotam Kenneth
FRC #2212
SavtaKenneth will become famous soon enough
Re: Project Wide Parameters
Which programming language are you using?
In Java and C++ you can create a class with all the variables defined as 'public static' and then you could have access to them from any file from the project. If you named the class Vars and a variable inside it var1 accessing it (in Java, I don't remember C++ syntax sadly) would be
Code:
Vars.var1
2012-Present Referee
2014 & 2015 Israel Regional Volunteer of The Year Award
2212 alumni
Unread 05-31-2011, 12:38 AM
lemiant's Avatar
the Dreamer
AKA: Alex
Code:
Vars.var1
This is for autodesk inventor.
Unread 05-31-2011, 09:20 AM
DMetalKong's Avatar
DMetalKong DMetalKong is offline
AKA: David K.
DMetalKong is a jewel in the roughDMetalKong is a jewel in the roughDMetalKong is a jewel in the rough
Send a message via AIM to DMetalKong
You can link excel tables to Inventor files.
This Youtube video shows how.
