Go to Post The only thing more dangerous than a Programmer with a screwdriver is a Hardware Designer with the root password... - kmcclary [more]
Unread 21-06-2011, 14:42
BrandonD-1528's Avatar
BrandonD-1528 BrandonD-1528 is offline
Mentor
AKA: Brandon Dusseau
FRC #1528 (Monroe Trojan Robotics)
BrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the rough
MARCStats 2.0.0 Out
In case anyone's interested, the source for MARCStats 2.0.0 is available at https://bitbucket.org/Turaiel/marcstats or can be downloaded in zip format at https://bitbucket.org/Turaiel/marcst...1216daa1d2.zip
Attached is a bare-bone copy of the SQL database as well. If you want to test it, you will need to create your own user accounts. There is no utility for that yet. Also keep in mind that the password must be MD5 encrypted when it's inserted into the database. Here are the available user levels:
1 - Registrar - Can take attendance for registered teams
2 - Data Entry - Can add and edit teams and match data
3 - Administrator - Can access system settings
Additionally, I'm attaching the dbconfig.php file which needs to be added to the root of the system. This file contains your mysql login information.
PLEASE let me know if you run into any problems. The scoring has been tested a bit, but not fully yet, so it's very important that you let me know if there's a calculation problem.
NEW IN 2.0.0:
Code:
   - Removed skipped match protection
   - Removed incorrect surrogate warning
   - Added automatic data recovery in case of failure
   - Combined match add/edit forms
   - Added pink ribbon graphic for local event
   - Rewrote/condensed scoring backend
   - Dropped clock shadow to conserve loading time
   - Added limited jQuery UI library
   - Upgrade to jQuery 1.5.1
   - Simplified match add/edit interface
   - Iconified front page
   - Replaced old icons with FatCow icons
   - Increased clock check interval to 1 second
   - Removed non-functional menu options
   - Added function to find max score
   - Cleaned up match editor
   - Updated scoring code to 2011 game
   - Removed TV announcement from system setup
   - Hid admin login from view
   - BUGFIX: Changed handling of Red Card and Surrogate flags
   - BUGFIX: Changed method in which Home and Logoff buttons are displayed
   - BUGFIX: TV match display no longer fails to update if less than 5 matches are completed
   - BUGFIX: Calculation errors in editing matches fixed
   - BUGFIX: Set clock to display "12" rather than "0" for the hour at midnight
Brandon Dusseau (website)
Monroe Trojan Robotics mentor
Software Engineer
Michigan Tech alumnus
