Go to Post As Murphy as my witness, things happen and will continue to happen. - Pavan Dave [more]
Unread 22-06-2011, 16:23
ElliotCourant's Avatar
ElliotCourant ElliotCourant is offline
Elliot Courant
AKA: Elliot Courant
FRC #3038 (ICE Robotics)
Rookie Year: 2010
ElliotCourant is an unknown quantity at this point
Compressor Pressure Sensor
Is there a way to tell what the pressure is for an air compressor or on a valve from windriver C++. something like "m_compressor.GetAirPressure();" function.
"Error, Cannot Find Back-End!" -WindRiver C++ Error
"If you aren't getting any errors while you are programming, then you are doing something wrong." -Elliot Courant
Unread 22-06-2011, 16:30
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Compressor Pressure Sensor
No. Because there isn't a sensor in the standard system that measures air pressure.
You could buy one, it's called a pressure transducer, but they can be fairly expensive.
The best you can do is check if the pressure switch has been tripped to see if it thinks more pressure should be pumped or not.
Pretty much we can only trust it to indicate:
  • OFF = pressure has been at 120psi recently and it hasn't yet dropped below 95psi
  • ON = the pressure is not 120psi
Unread 22-06-2011, 16:47
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
To do that, you'll need to install a sensor that can measure air pressure, and connect it to the robot control system so you can read its value. There was one in the 2004 Kit of Parts, made by Texas Instruments if I'm remembering correctly. It provided an analog voltage proportional to the pressure.
Unread 23-06-2011, 09:59
Elliot Courant
AKA: Elliot Courant
Rookie Year: 2010
Is there a way to make one of those sensors because we didn't have a team back in 2004?
Unread 23-06-2011, 22:17
DonRotolo's Avatar
Back to humble
FRC #0832
"Make" a pressure sensor?
Technically, if some company can make one, so can you. I suppose.
But practically: No. You should buy one.
Something like this should do.
Unread 23-06-2011, 22:57
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Well, maybe not that one exactly—it doesn't have a barbed fitting for attaching a tube. (I've seen similar ones designed to accommodate tubing in that way, but I'm not sure if they're sized for FRC-legal tubing.) The one in the old KOP was embedded in a brass NPT-threaded fitting, and avoided tubing altogether.
And definitely check the rules closely before using these in competition. They're exposed to air pressure, so would almost certainly be considered a pneumatic part, and therefore be subject to stringent regulations.
