Go to Post I can't wait until IFI starts their FRC sized competition and quickly overtakes FRC. - AdamHeard [more]
Unread 03-07-2011, 03:02
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
How Can We Make American Students Smarter?
Maybe Mr. George Bush was not so uninformed when he pushed for No Child Left Behind. This is not a discussion on NCLB, but it was a result of low test scores nation wide. May be I am just stuck in a bubble of education right now, I consider any ACT score under 30 and SAT score under 2000 as "bad". Now it may shock you that the national averages are significantly lower than I have even heard of anyone getting.
National ACT Averages (2010)
Code:
Composite: 21.0
English: 20.5
Math: 21.0
Reading: 21.3
Science: 20.9
Now, the scores with the most kids
Code:
Composite: 21
English: 21
Math: 16
Reading: 20
Science: 20
Look at that math score. 180,723 kids got a score of 16 on the Math section.
National SAT Averages (2010)
Code:
Critical Reading: 501
Math: 516
Writing: 492
I find those figures appalling. Now, how can those averages be so low? Is it the nature of the tests themselves? Is it the fabric of how the educational system run? Are they mostly due to socioeconomic situations? How can we fix this problem?
Sources:
http://www.act.org/news/data/10/pdf/...utm_medium=web
http://professionals.collegeboard.co...report-cbs.pdf
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 03-07-2011, 05:58
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Re: How Can We Make American Students Smarter?
I wouldn't necessarily conflate NCLB-mandated testing with university-entry tests like the SAT and ACT. They're aimed at different things.
The impetus to perform well on the college tests lies first and foremost with the student: their future will almost certainly depend on it. As for the NCLB testing, depending on the jurisdiction, a passing mark may not have any effect on the student's promotion to the next grade, or their eventual admission by a university. Those tests are primarily a way to measure schools and other administrative entities, and as a result, the schools are the ones that take them most seriously.
Nevertheless, you're right to wonder what methodological issues might be affecting the statistics, and right to question the policies that govern the education system.
Incidentally, as far as NCLB is concerned, it was bad policy, but with reasonable intentions. The key flaw was assuming that performance on standardized tests would necessarily be an accurate predictor of students' knowledge. This is only true to the extent that you hold everything—and in particular, the curriculum—constant. As soon as you adjust your teaching style and methods to focus on the testable items, without also revising your definition of knowledge to focus on the test content, you've introduced a confounding effect.
One example of this might be a breadth-for-depth tradeoff: students become more proficient in the types of language skills required on their test, but spend less time being exposed to a variety of literature, or practicing different writing styles. If this increased their test scores by 2%, did that curriculum change make the students 2% smarter (in terms of language)? It seems obvious that it probably wouldn't have, yet this is an expectation against which the schools are being measured. (Note that it isn't inconceivable that there actually was a benefit to the new teaching method, measured against a constant standard—maybe 0.4%, to pick a number for illustrative purposes.)
The other glaring flaw with NCLB is that it takes funding away from schools that score poorly. Given that change and improvement tend to cost money, this is exactly the wrong move. It comes from a misguided belief that it would be irresponsible to throw good money after bad—but that's just folk wisdom substituting for an actual understanding of whether fiscal irresponsibility was actually involved in a school's lack of success. The architects of NCLB in effect blamed low educational outcomes on mismanagement, and therefore tried to punish the bad managers by cutting their funding. Unfortunately, they never figured out a rigourous way of determining whether the management was doing a good or a bad job in the first place—and their proxy, student test scores, is a terrible approximation in a substantial number of circumstances.
Unread 03-07-2011, 06:44
Talks Too Much Talks Too Much is offline
FRC #0708 (Hardwired Fusion)
Team Role: Student
Rookie Year: 2011
Talks Too Much is a glorious beacon of lightTalks Too Much is a glorious beacon of lightTalks Too Much is a glorious beacon of lightTalks Too Much is a glorious beacon of lightTalks Too Much is a glorious beacon of lightTalks Too Much is a glorious beacon of light
While I also hate NCLB, it's not because it caused low SAT/ACT scores. Both tests are curved (based on a standard distribution, hence the median scores having the most recipients), and the reason the average scores are average is because the College Board and ACT, Inc have chosen to curve the tests to make those the average scores.
Unread 03-07-2011, 12:33
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
The international average for math is 587 and writing is 510, only the critical reading is below Americans' average. International students are taking the same tests; why are they "better" at it than Americans?
Unread 03-07-2011, 12:40
Team Role: Student
Rookie Year: 2011
The SAT and ACT are tests for entry into American universities, the majority of applicants to which are American. The pool of international test-takers is much smaller and far more self-selecting than domestics. Honestly, I'm surprised the average international scores aren't much higher than they are.
In some US high schools, all students (even those not planning on attending college) are forced to take the test, and how motivated do you think they are to do well? They probably skew the numbers a bit.
Unread 03-07-2011, 21:25
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Molten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond repute
Smarter how? There are many forms of intelligence in this world. Not all of them are related to books. Some people know language. Some people know math. Some people know people. Some people know other things. When discussing something like this, just be aware that a part of the reason some students don't do well on these tests are because they are busy with other things in life. Perhaps the only way to improve test scores are to remove some of these distractions. They range from troubled neighborhoods to family issues. Any restructuring of the education system will have minimal impact unless you pair it with various programs to directly motivate the individual student. School life and home life both impact the student equally.
Jason
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 05-07-2011, 12:46
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Michigan public school students are required to take the ACT as part of our state standardized testing (MME). Based on my personal experience with my classmates, probably about 1/4 of my classmates took the test seriously (most of them utilizing study aids or taking classes), and the remaining 3/4 couldn't care less. I would bet that the 1/4 who cared scored far higher than those who didn't. I think that part of the problem is that many students don't see reason to score well: it could be that standards are not set in the home, they don't plan on attending college, there aren't social pressures to conform to, they simply don't care about their future yet, etc. If we found ways to improve motivation from a younger age, I'm sure that general education (NOT just test scores) would improve as a whole. Personally, I think that a more applied, personal education (showing students WHY they should know the material that they're being taught, and giving some real-life examples) is one of the solutions.
Originally Posted by sanddrag
First way to fixing education is smaller class sizes. I don't think anyone disagrees with that.
I couldn't agree more. I felt that the learning environment was far better in my 20-student Humanities class than in my 29-student Pre-calculus class. Unfortunately, as school budgets shrink, the size of mandatory couses only grows.
One of my friends initially scored an 18 on his ACT. Another one of my friends scored a 36. I scored a 29. Like a lot of universities, I consider a 23 to 25 to be a good, average score. My high school's averages were very close to the national ones, and our district prides itself on being consistently ranked one of the top in the nation (which I have issues with, but that's not a rant for here). Back to the friends above...they going to a respectable state university as a music major and to Harvard, respectively. What scores are considered "normal" or "good" to a person depends on the social norms in their area, as shown by the differences in our views.
All that being said, I am of the opinion that the ACT is a horrible way of determining a person's education/intelligence, and should only be used for that purpose when other indicators are also being looked at (such as GPA, social concerns, and district-wide numbers).
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 03-07-2011, 21:36
DonRotolo's Avatar
Back to humble
FRC #0832
Please be sure to separate the test score from the value of the person: failure to do so can lead to some bad things for society. PM me for examples from history if you can't think of any.
Not everyone is smart, but you don't have to be in order to survive and flourish in this world. You don't need a PhD to dig a ditch nor do you necessarily want a PhD digging one, but ditches still need to be dug.
What is more important than raw intelligence is a strong work ethic. I can guarantee success to someone willing to work for it, just as I can guarantee failure to someone who believes work is unnecessary for success.
Funny how our little robot team emulates life.
Unread 04-07-2011, 04:17
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Another way would to make the teaching profession more enticing to industry professionals, and easier to get started in. The bureaucracy, red tape, and cost a person must go through to become a teacher is ridiculous.
Unread 05-07-2011, 13:30
Molten's Avatar
AKA: Jason
If the SAT is supposed to be a metric to compare students, shouldn't the average be kept around 500 at most? Otherwise, how are you going to tell who is excelling and who is behind? I read about a test that got rid of their out-of-context questions(such as analogies) and added in-context questions. This was a more accurate indicator of the skills needed to excel in society. This is just one of the many things SAT makers need to consider doing. Also, part of the reason test scores are low is because the strategies promoted to take the SAT. They suggest to only answer questions your confident about and thats good if your not comfortable with a subject. However, if you are comfortable with the subject matter you should answer every question. I had a friend that was taking BC calculus in high school and scored a 500 on math his first time around. I gave him this advice and he went up to 720. This just shows one of the flaws in society. Not only do we have a one-size-fits-all test, but we also promote a one-size-fits-all strategy to take it.
Considering many people commenting how poor the test is at testing academic skill, how would you test it? How would you change the test?
I would change the math questions to involve more applicable word problems and less that don't make sense. I would add some multiple choice questions that asked about math theory rather then just math practice. That way we can accurately tell how many people knew the approach. Questions such as, which method of factoring would be appropriate for this problem? For english, I would get rid of words that nobody has used. Usually they just test for who prepared for the SAT rather then who knows the word. I would combine the english and the writing into one test. They are both part of the same subject and should be dealt with as such. The writing should have more papers to write and be shorter in length. That way you can ensure each person talks about something they know and something they don't.
Full disclose: I got a 800 on the math, 580 on the english, and 420 on the writing. The math wasn't because I was great at math rather because I am fast and cautious with my math, english was largely luck(I guessed on half of the analogies), and the writing was because it was a very weird topic for me to write about. I state this because it shows clear implications into my feelings of the test and should show any bias that I may have.
Jason
Unread 05-07-2011, 15:14
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Rookie Year: 1999
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
How do we make American Students Smarter?
It takes more than a school system, more than a teacher, more than fancy standardized tests. There is an old saying, "It takes an entire town to raise a child". It applies here as well.
It has to done on multiple fronts such as the following (IMHO).
1) Parent accountability and responsibility to ensure their children do attend, do homework, and the parents HELP and participate in the education of their children. Granted that's not always possible, broken homes, etc.. , but lack of parent responsibility and accountability should be the exception, not the norm. Perhaps a "Bad Parent Tax" should be levied.
2) Give Teachers greater ability to enforce greater classroom control and discipline. The teachers hands are tied today. Granted teachers should not be disciplinarians, but at least give them ability to maintain order without fear of reprisal, or child abuse charges,etc.. Too many times have I heard of one or a few disruptive students impeding the teachers ability to teach those that truly want to learn. This disruption must be stopped cold. All parents and students sign a wavier giving teachers this ability.
3) Raise Standards. The standards are far to low today. The passing test results have more to due with "funding" than with actual educational success. It's truly sad that so many that I interview today, even college graduates can't even write a complete sentence, and have even worse verbal skills. Believe me this area is my own personal worst, but what I see today is even poorer than my own.
4) End or Modify NCLB. While concept is worthy the implementation is faulty. Too many students are basically pushed through without being given the proper education in order to simply to fulfill this objective. It is not achieving it's goal, it's have the opposite effect.
Just for the record, I'm not a teacher.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 05-07-2011, 17:49
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
I suggest all to watch "Waiting for Superman"
http://www.waitingforsuperman.com/
http://www.imdb.com/title/tt1566648/
A great documentary on the current school system and its flaws.
Unread 05-07-2011, 18:50
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
While not a discussion on NCLB I do want to make a trivia point.
NCLB wasn't a Bush'ism. It was a bipartisan effort that was a pet project of President Bush and Senator Kennedy. It was something Kennedy wanted to do for a long time and when Bush entered the Presidency they had a common project to work on. This is something that pundits conveniently forget.
Ed Barker
Unread 05-07-2011, 22:42
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Speaking from my experience only...
You want to make young people better students, learn more and be "smarter"? You have to give them a reason to do so. There needs to be a light at the end of the tunnel, a carrot, a reward. There are those few that see getting better grades than those around them as enough of an incentive. Some like the approval of family, parents, and teachers. Some want to attend a better university and so they will work like mad to get better grades. For the rest, none of these things work. It was not until I saw that electronics was fun and that it pays, that I started to really get good grades. I thought you needed to learn history to be able to answer questions on quiz shows. English, why? I already speak and write. It was not until I decided they were important for me did I start to really work hard and even fight for grades I deserved. And yes, everyone told me all of the above, "you need to get better grades because..." "Alan can do better, he just choses not to..." "You want to go to a good university don't you?" Well now I know, I needed to work hard to allow me to choose my career, not have one thrust on me. I enjoy what I do everyday and thank God that I found this out just in time.
Al
WB9UVJ
www.wildstang.org
________________________
  #15   Spotlight this post!
Unread 05-07-2011, 23:10
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
I have been told I was a unique case by my school counselor. I guess I just was not the type for public education. I am the type of person that disregards grades, rank, awards, positions and stuff like that. Some would call me an undisciplined rebel. Sure, that sounds like me in some perspective. I used to scoff at those kids that would compete for the higher grade. In my eyes, they were doing it all wrong. The purpose of education is NOT to just get good grades; I knew this from an early age. I still facepalm at those kids who play the system to get the highest GPA or rank in school. It is ridiculous what some kids would do. I was appalled by that type of behavior; yet it is those kids that turn to me and scold me for reading about quantum physics instead of reading about capacitance. I know I have my flaws, I know that I won't get into a good college if I keep this attitude up. I have to play by the rules of the game or I will be purged out of the system. Also for awards, I personally think awards are ridiculous. The person receiving the award knows his or her accomplishments and dies not need a committee of people to confirm for him/her.
Sir, I am just like how you were. I have been receiving the comments "David can do better than this, he just needs to try harder."; "David is a smart boy, his grades do not show it". According to the system, I am dumber than I am on paper. That, I believe is my problem. I remember I was that kid that finishes tests 10 minutes faster than everyone then get a 100% on it. That was mostly due to the fact that all I ever read was nonfiction books, often higher than my grade level. I read extensively about biology, geology, anything science related. Then came high school, where they took things a little farther. Sure, I would still be acing every single biology test, but I still only had a C or B because I never did the work. In fact, I was the only student that year that got over a 100% on the final yet I still ended up with a C in the class because of my ignorance. I never did the work, and when I did, it was done half assed, bare minimum. That habit is not a good thing to have. Then I had that same attitude the next year, including during robotics. if anyone remembers, I was the kid that played Madden on the computer the whole time during competition. My grades were also terrible by then. Junior year came and went. I still have not recovered from my bad habits. But I plan on changing that. I spent the summer so far studying calculus and physics with calculus.
Also, a side note, thank you for suggesting Bradley. I will be going to an information meeting in 2 weeks.
