Go to Post With people from the high northeast, mid east, mid west and far west all in one hotel room, we had the time of our lives simply by sitting there. - Keith Chester [more]
Unread 07-07-2011, 14:26
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
Team Role: Leadership
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Pnuematic fittings
It appears that there aren't any standard push-to-connect pnuematic fittings in the kit (unless I'm missing something: http://www.usfirst.org/uploadedFiles...%20Rev%20E.pdf) so I'm wondering where does everyone get the little plastic push-to-connect fittings?
Unread 07-07-2011, 14:27
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: Pnuematic fittings
Most industrial supply companies will source them, especially those dealing with pneumatics.
For low quantity we usually just use mcmaster and add them to our normal orders.
Unread 07-07-2011, 14:49
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is offline
on walkabout
FRC #2175 (The Fighting Calculators)
Aren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond repute
Also check out SMC's website.
We've had the same few (large) bags of them for a little while now, so I couldn't say where we got them (maybe even in the 08 or 09 kit or something?). Odd that they give you all that brass and no quick-connects...
Unread 07-07-2011, 15:52
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
The push-to-connect fittings were offered this year as one of the choices in the extended FIRST Choice KOP through AndyMark, so keep an eye out there next year too.
We order extras from a variety of places, usually chosen based on building a bigger order. Here's a T-connector for instance: http://www.alliedelec.com/Search/Pro...&MPN=KQ2T07-00
Other common fittings are listed at the bottom of that page too. P.S. Same as Chuck's link above.
Unread 07-07-2011, 16:28
lemiant's Avatar
the Dreamer
AKA: Alex
What ports do our pnuematics have? These (http://www.alliedelec.com/pneumatics/fittings/) all have NPT 1/4 or 1/8 threads, but the festo solenoid (http://www.andymark.com/product-p/am-0888.htm) has M7 threads. Will these be able to interface?
Unread 07-07-2011, 16:33
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
Princess Auto carries quite a selection. www.princessauto.com. The cylinders they sell are metric but they carry both metric and imperial fittings.
Unread 07-07-2011, 16:44
on walkabout
FIRST requires 1/8" NPT, but that's just the diameter of the airflow cylinder (technical term anyone?... NPT I guess ). The threads will vary. All of the brass fittings and quick connects teams usually get (including all the ones posted so far, I think) have the same standard thread (not sure exactly what it is). However, the newer Festo (and SMC I believe), while they have the same NPT, they have a different fitting that you have to buy from the mfgr (as far as I know), which uses the M7 you are seeing on their website. These interface with the rest of your interface then with the standard 1/8" NPT tubing between the two different types of fittings.
Unread 07-07-2011, 16:53
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
I know of no FIRST requirement for fitting thread size only hose size.
NPT = National pipe thread
Unread 07-07-2011, 17:10
on walkabout
Oh... that's news to me, thanks for the enlightenment
I knew it was just the hose size restriction, but not knowing the acronym I assumed that was it... You learn something new everyday!
Unread 07-07-2011, 17:11
lemiant's Avatar
the Dreamer
AKA: Alex
Would this be legal hose?
http://www.princessauto.com/power-tr...matic-hose-red
It's the right dimension, but 125 max PSI seems to be cutting it a bit tight.
Unread 07-07-2011, 17:54
George C's Avatar
I don't recall Princess Auto carrying the hose but a new colour hose comes in the KOP every year - the supplier was taking suggestions at the championships. You can buy approved hose from McMaster Carr. The big advantage of Princess Auto is that you have two in Calgary and they're a lot cheaper than McMaster Carr.
Incidentally, National Pipe Thread (NPT) is tapered at 3/4" per foot or 1:16 so that the threads lock to give a seal (assisted by Teflon tape or pipe dope). 1/8 NPT has 27 threads per inch. We had an issue this past season with some Festo solenoids that had been anodized after threading so that the push fittings wouldn't thread in. We had to re-cut the threads with a 1/8 NPT tap.
Unread 08-07-2011, 11:09
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
Rookie Year: 2007
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
McMaster has push fittings.
Unread 07-07-2011, 17:21
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
IndySam is correct except for
Originally Posted by 2011 rules R66 section B
B. Solenoid valves with a maximum ⅛” NPT port diameter, and a maximum Cv of 0.32 (if non-KOP valves are used, the team will be required to provide part documentation validating that the valves meet these constraints).
The hose size that IndySam is talking about is:
Originally Posted by 2011 rules R66 section C
C. Additional 0.160” inside diameter pneumatic tubing functionally equivalent to that provided in the KOP, with the pressure rating clearly factory-printed on the exterior of the tubing,
The OD of the Freelin-Wade tubing in the KOP is 0.25" and that is the push-to-fit size needed.
If you use push-to-fit fittings, I suggest getting a tubing cutter and ensuring that you cut the tubes square. Angle cuts cause so many leaks ...
Also, these are last years rules ... next years may (or may not) be radically different. YMMV.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 07-07-2011, 17:26
on walkabout
As for the pressure, 125 psi should be just fine (correct me if I'm wrong). I'm pretty sure all the hosing we have is labeled with that as well. Our pneumatic systems never get above that on the high end (k maybe like 130), and I'm guessing that published number is before the safety factor of at least 2.
  #15   Spotlight this post!
Unread 07-07-2011, 20:58
IndySam's Avatar
Excellent point, that one tool will save you hours of leak fixing and should be in the toolbox of anyone using pneumatics.
