Go to Post Look at FIRST 7 years ago. Look at FIRST now. Thanks Bill. - Steven Donow [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 20-07-2011, 20:51
bearsomg bearsomg is offline
FRC #1511
bearsomg is an unknown quantity at this point
PWM Pulse Help
I'm trying to design a computer program that will use the digital outputs of a computer's parallel port to control a jaguar through PWM. From what I know already, one pin goes to ground, but what are the other two pins on the PWM cable used for?
Also, how would I calculate the pulse on/off time to sending high/low values through the PWM pulse pin to set the Jaguar to certain speeds (I.e. what would I need to send through the 3 pins to get the equivalent of half speed on the jaguar output)?
Justin
FIRST Team 1511 - Rolling Thunder
Unread 20-07-2011, 21:43
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: PWM Pulse Help
http://www.chiefdelphi.com/forums/at...d=13112133 46
http://www.chiefdelphi.com/forums/at...4&d=1291927655
Name:	Jag PWM input.png
Unread 20-07-2011, 21:53
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: PWM Pulse Help
The red or center wire is unused by a Jaguar.
The white wire is for the signal pulses.
Unread 20-07-2011, 23:36
windtakers windtakers is offline
AKA: Blake Dansfield
FRC #3620 (Average Joes)
Rookie Year: 2011
windtakers is an unknown quantity at this point
Re: PWM Pulse Help
white wire= signal
red=power
black=ground
Unread 21-07-2011, 08:02
Ether's Avatar
Rookie Year: 1969
Re: PWM Pulse Help
Originally Posted by windtakers View Post
white wire= signal
red=power
black=ground
red=power NOT USED. read previous posts.
Unread 21-07-2011, 11:57
s1900ahon s1900ahon is online now
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Re: PWM Pulse Help
Internal to the Jaguar, the white wire (which contains the PWM signal) is put through the diode of an opto isolator and the current returns via the black wire. As pointed out, the red wire isn't used. The other side of the opto isolator goes to a GPIO pin of the microcontroller in the Jaguar which measures the pulse width.
You can get the Jaguar's schematics which might provide you more insight and help with your interfacing exercise.. The CD accompanying the developer's version of Jaguar are available for free download on the TI web site. See http://focus.ti.com/docs/toolsw/fold...-bdc24-cd.html
Also be aware of the pulse width and frequency requirements. By default, the Jaguar uses a wider pulse width range than standard hobby servos or the Victor. NI and TI (then Luminary Micro) worked together to provide more granularity to the output and therefore the PWM width is wider. It can also be operated with a period in the range of 5-30 ms (5 ms for a 200 Hz update rate). If you need it to work in the same range as a standard hobby servo, you'll need to calibrate the Jaguar, and remember to recalibrate it if you put it back on an FRC robot later.
-Scott
