Go to Post I may be right or wrong but I’ll be happily senile doing it. - ebarker [more]
Unread 27-07-2011, 14:17
Chris is me's Avatar
AKA: Pinecone
Aluminium Gears
Hey CD, I'm looking for any and all COTS aluminum gears on the market. In particular, larger 32DP gears with decent face widths would be really cool. I realize aluminum gears are pricey and hard to find, but I wanna know if CD has any sources I don't know about and couldn't find on a Google search. Thanks!
Unread 27-07-2011, 14:29
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: Aluminium Gears
I recently noticed that the tetrix gears are .25" face width 32DP. Using an 8T brass pinion to the 120T that's 15:1!
Sdp-si is the only place I've found aluminum gears at a reasonable price (aside from the limited 20DP selection at AM). Although I've only seem them up to 3/16".
What is this for?
Unread 27-07-2011, 14:40
AKA: Pinecone
Re: Aluminium Gears
I'm interested in prototyping various gearbox arrangements to see if I can save space or weight in small reductions. I also want to test a drivetrain with these gears. I haven't run the numbers on tooth loads, though.
Unread 27-07-2011, 15:03
Chris Hibner's Avatar Unsung FIRST Hero
Chris Hibner Chris Hibner is offline
Eschewing Obfuscation Since 1990
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Chris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond repute
Re: Aluminium Gears
Back when I was on 308 we did aluminum gears in the drivetrain for two seasons (2001 and 2002). I think we used 24 DP in 2002 and they lasted the entire year until the first match of the world championship finals - then they shredded. Pretty bad timing. I think you can find pictures of the gearbox carnage somewhere on this site. In fairness to those gears, we're pretty sure the shaft shifted leaving only about 60% engagement along the face width.
In 2002, those gears were 1/4 inch face width, but we sandwiched multiple gears together to increase the effective face width. I really wish I could remember the source where we bought the gears. Although, as long ago as that was they may not be in business any more.
One important note: when we were doing tooth stress calculations, I remember that 24 DP was pretty marginal in later stages of the gearbox, so I would expect 32 to not be able to withstand the loads without getting crazy with the face width. Just be sure to do all of the calculations and double check them.
In 2001, we machined custom aluminum gears because we were worried about tooth loads with small gear teeth. I want to say we made them in the neighborhood of 12 to 16 DP. They looked a little weird, but worked great.
An ounce of perception is worth a pound of obscure.
Unread 27-07-2011, 16:06
Redo91's Avatar
Redo91 Redo91 is online now
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
Re: Aluminium Gears
Check out JVN's post about aluminum plate gears here.
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 27-07-2011, 17:50
AKA: Pinecone
Re: Aluminium Gears
That's the idea, but unfortunately we don't have any sponsors with a laser. The hope is to buy a bunch off the shelf and play with them.
I'm not sure if the Tetrix gearset is worth trying or not, I imagine they are probably pricy.
Unread 27-07-2011, 17:56
AdamHeard's Avatar
Lead Mentor
Re: Aluminium Gears
Get some sponsors then, google, phonebook, etc... It doesn't have to be laser either, could be waterjet.
The tetrix gears aren't really bad at all in price when compared to other 32DP aluminum gears. a 120 tooth for $30. Now that I know about it, we're certainly interested in doing a 32DP based gearbox for 500 sized motors as 32DP pinions are cheaply and easily available in varied sizes at EVERY hobby shop.
I think effective design and pocketing of existing steel gears would yield more bang for your buck than investigating aluminum gears.
You should also learn how to calculate gearstrengh using Lewis Bending Numbers, once you do it's trivial to determine if a gear will survive; no need to experiment to solve a problem that's been solved for a hundred years.
Unread 27-07-2011, 18:01
AKA: Pinecone
Re: Aluminium Gears
We're certainly working on it. Our economic region isn't particularly bright (Troy has 14% unemployment and I bet Latham isn't much better), but if we do we'll see. I'm just generally a fan of modifying COTS parts in house, since that's more reliable than counting on the donated services of a sponsor, plus it puts less stress on them.
That's probably true, I'm just interested in seeing if we can throw a few bucks at the problem to avoid having to pocket steel.
I've heard that Lewis numbers tend to be conservative, but I've still been meaning to learn. Thanks for the reminder. Lewis numbers do say my drivetrain application should hold up.
Unread 28-07-2011, 07:47
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
Team Role: Mechanical
Rookie Year: 2007
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: Aluminium Gears
Waterjet is probably better for this application. Laser would require plate gears since all lasers are limited in the thickness of aluminum they cut (some more so than others) due to aluminum's reflective properties. Waterjet could cut the proper thickness material in one cut.
Chris, I wish I could help you out, but our metal shop has been unresponsive recently on account of new business and tied up equipment.
Unread 28-07-2011, 10:04
AdamHeard's Avatar
Lead Mentor
Re: Aluminium Gears
You wouldn't want to cut direct to thickness on the waterjet anyway with the draft angle created (unless you've got a sponsor with a tilting head).
You'd want to stack thinner gears with both processes, and laser arguably is the faster process for thinner material.
Unread 27-07-2011, 20:53
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: Aluminium Gears
I would be extremely concerned about runout in a high speed application such as the initial reduction(s) in a gearbox, if using this method.
The tetrix gears are probably 5000 or 6000 series aluminum which is less than ideal for any high torque situation.
2001-2004: Team 100
2006-Present: Team 254
Unread 28-07-2011, 00:46
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is offline
on walkabout
FRC #2175 (The Fighting Calculators)
Aren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond repute
Re: Aluminium Gears
If you've found a bunch of reasonably priced 32dp aluminum gears that just aren't wide enough for your purposes, you can always just stack them. I'm no expert, but that seems to accomplish the same thing, in terms of pressure. Maybe not so much in terms of the statics of the material stress or whatever is going on there, since the gears aren't actually connected, but you're at least distributing the same load over a larger area.
Unread 28-07-2011, 01:32
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
Re: Aluminium Gears
There was a team at CMP that used anodized aluminum gears that were similar to the gearset that andymark sells, i believe they were going to try to start selling them, does anyone else have any more information?
Unread 28-07-2011, 01:47
R.C.'s Avatar
Happy Birthday! R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Re: Aluminium Gears
That was Team 1323/973. I'll put up a pic soon.
-RC
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
  #15   Spotlight this post!
Unread 28-07-2011, 02:00
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Aluminium Gears
And the draft angle.
