Thread Tools |
Rating:
Display Modes |
Autodesk Inverter Pro 2012 - MasterCAM - CNC
By some miracle, our school was able to obtain a CNC machine which is intended to be used in classroom situations and by our FIRST Robotics Team. I was involved in it's uncrating, set up, and about a 20 minute "Here's how it works" session from a technician that just really wanted to go home at 6:30 PM. We intend to rectify that.
I kept asking, "Can we go from Inventor Pro to a finished part". Answer..."yes of course you can, with a translator..." and what boiled down to "A lot of luck". In the long run, no matter how many return trips and brow beating we do, I don't think he's going to be much help. So, has anyone else out there gone through this? Can you point out some tutorials or related info? |
Re: Autodesk Inverter Pro 2012 - MasterCAM - CNC
I don't know what software or controller your machine uses but chances are it runs standard G-code. What I usually do is create a 2D .idw drawing in Inventor (in 1:1 scale of course) and then save that as a DXF. I then open the DXF in MasterCAM X and create the toolpaths, export the G-code, and load it into the machine. I suppose it's also possible to import a 3D model into MasterCAM but I don't do it that way for the simple stuff I do.
Do you have MasterCAM? If not, I'd recommend it. There are alternatives but in my opinion they don't compare. |
Sanddrag,
The "system" came with MasterCAM x5 (?). During the hocus-pokeus set up demonstration, I thought I saw the MasterCAM software guide the production of a "part". Problem was, fingers were flying, keys were pounding, mice were zooming and it was hard to tell what was happening. The installer had taken 6 hr to get it going and just really wanted to go home. But we did ask about Gcode, and were able (actually we had to, to change to a bit we had that the machine didn't know about) edit it. But the whole process was not pretty. In a nut shell, we have Autodesk Inventor Pro 2012 (and we've become much better with it), MasterCAM x5 (and supposedly all the translators and libraries) and the following machine.... http://www.techno-isel.com/Education1/Patriot.htm So, are there tutorials on how to go from Inventor, where we currently do all our designs, to finished part? Thanks for your patience all! Doc Last edited by docdavies : 03-08-2011 at 15:42. |
Doc,
I sent you an email, I can for sure help you with this. Our rep was very helpful when we started. Who did you buy this through? -RC |
I personally have used Autodesk Inventer 2009 with MasterCAM 9 and a CNC.
Basically what I do is I create the part as a 3d model (.ipt) even if it is just going to be a plate that will be machined. From there I create a drawing (.idw) at 1:1 scale and save it as a DXF. MasterCAM is able to import the DXF directly and from there I create the tool paths that are needed. To finish up in MasterCAM I export the tool paths into G-Code (also called post processing) and because the machine I work with does not have an automatic tool changer I post each tool of the program to a separate G-code file. I have played with MasterCAM x5 and it does all the same things that 9 can do its just the menus are different. The same goes for Inventor 2009 just has a different layout than 2012 (and its more stable IMHO) Hopefully that explains it a little more. |
Also, depending how your machine works, you might be able to save time by posting out all your tools in one program, with a M00 command between each one. This will force the machine to always stop when the M00 is reached, allowing you to change tools, and then start up where you left off and machine with the next tool. |
Folks,
Everything you are suggesting seems great. But please remember, you're like a nuclear physicist attempting to explain a Thorium reactor to a 3 year old. We are just not working off the same knowledge base....from my side, I really need to get up to speed! So, can you suggest any GOOD books or on-line tutorials that would at least teach me to speak the same language, and have concept of how things SHOULD happen, even if I don't currently know how they do happen? On slightly more depressing note, the more I look into the actual CNC machine we have (link provided above), it looks more like it's meant to be a teaching machine for use on wood, plastic and maybe "soft" metals. And not a machine that's going to be suited for our robotics builds. Thanks, Doc |
Well, progress. My younger son, who's just started FRC last year as a freshman, took an Inventor Pro File that had been graciously converted by RC to run under MasterCAM, and got it to run in the machine on a chunk of wood. Following several suggestions gleaned on-line we're picking up some carpet tape and will try to cut the piece out of aluminum during a Sat. summer build session.
I'll let you know how that goes. Thanks again to the FIRST community for all your help..... Doc |
#10
Just a suggestion: When practicing, you may want to consider using styrofoam (the pink or blue stuff sold as Home Depot/Lowe's) or, even better, machining wax (google it, several online suppliers). Both are soft, inexpensive materials that will allow you to machine things without damage if the tool decided to make a cut it can't. Aluminum is less forgiving. Bonus for the wax: Melt the chips into a cake pan and you have a new block.
#11
Don --> I like it! Since I've been spending a lot of time at Home Depot getting generators, extension cords, gas cans and such....I'll pick some up on my NEXT visit, which will probably be today.
