Go to Post After all, each day is fresh with no mistakes in it [yet]. - atomikitten [more]
Unread 10-08-2011, 17:46
Jedward45 Jedward45 is offline
FRC #2220
Jedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant future
pic: 2011 "Nova" Swerve Drive (Front)
Unread 10-08-2011, 17:47
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: pic: 2011 "Nova" Swerve Drive (Front)
I'd be very worried about those bevel gears, what DP are they?
Also, the steering sprocket setup, is that one solid piece?
Unread 10-08-2011, 18:31
FRC #2220
The DP is 32. They are a Boston Gear set. The Mounting Distances are up to spec with Boston Gear's technical drawings. Also, the hub of the Gear inserts into the wheel assembly.
The steering sprockets sit on a 1" OD Aluminum tube (3/4" ID). This tube is machined from a 2" diameter Aluminum rod because at the base of the 1" tube, a 2" mounting plate attaches to the rest of the chassis (Dark grey).
Hope that clears things up
Unread 10-08-2011, 18:43
=Martin=Taylor= =Martin=Taylor= is offline
run the trap!!!
FRC #0100 (The Wild Hat Society)
Team Role: Human Player
=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute
Wow. I once spent a long time designing a drive just like this. I have to say, this is a very good design!
I gave up on my design because I was worried about turning the modules. The very closest I was able to move the wheels was 4" wide. The effectiveness of a swerve is limited by how fast the modules can be rotated, and with only the window motors for rotation I figured this might be difficult with such wide wheels.
My next and final swerve design was a 45* module like in the 1625 teaser. In the end, this design wound up being more complicated to make then a conventional module and was only slightly smaller so I abandoned this too.
Its cool seeing all the new swerve designs on CD. I wonder how many teams will use swerve next year...
"Cooperation; because life is a team sport"
-Philip J. Fry
Unread 10-08-2011, 23:45
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
Peyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond repute
I don't know if we will use it next year but team 45 has started thinking about adding swerve to the list of drive trains we can construct.
4wd
6wd
tread
ball drive
swerve?
461 Westside Boiler Invasion
2016 Tippy Quarter finalist, Warren Finalist, IN State Semi Finalist,B^3 Double Finalist
2015 Indy Semi finalist, Purdue Quarter Finalist, IN State Quarter Finalist, CORI QF, R2OC Finalist, RAGE Winner
2014 Boilermaker Semi finalist, Crossroads Quarter Finalist, & CAGE Quarter Finalist
45 Technokats
2013 Boilermaker Quarter finalist
2012 CAGE Semi finalist & Queen City Champion
2011 CAGE Quarter finalist & Midwest Semi finalist
2010 CAGE Quarter finalist, Boilermaker Champion, & Washington DC Quarter Finalist
Unread 11-08-2011, 00:50
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Are they hardened? And is the gear's thickness drawn to scale? They seem rather undersized for a final drivetrain stage. I wouldn't proceed with those particular gears unless you've calculated the gear strength to verify the design—they're just too unlikely to be adequate.
Also, you didn't mean to include a differential, right? (I seem to recall a team having a design similar to this, but with differentials on all wheel pairs. Might have been 1140 around 2005.)
Unread 11-08-2011, 01:14
FRC #2220
Currently the gears are baseline steel.
As you probably know, selecting the Bevel Gears was by far the trickiest part of this design. If the mounting distances are too large, the wheel separation makes rotation of the module impossible. On that end, if you happen to know where I might find a hardened, spiral bevel gear set that fits near the specifications for under $120, I would greatly appreciate it....
Also, how exactly do you calculate gear strength anyways?
Unread 11-08-2011, 03:13
Rookie Year: 1999
My first instinct would be to check QTC (part of the Designatronics group familiar to many via their SDP/SI division). Although I realize it's not the ratio you were depicting above, you should probably look at this page, specifically SBS1-4020R and SBS1-2040L to get an idea of what's available, and what it might cost you. Those teeth are induction hardened to Rockwell C 48, which in steel, correlates well with a tensile strength of about 1 632 MPa (237 000 lb/in2, or really strong). The teeth are 1.0 module (or 25.4 diametral pitch), which I'd say is about as small as you'd want to go for a final stage of a drivetrain—and even then, only with a hardened gear.
And by the way, if you need more clearance for the pinion (too wide), you might consider dishing out the wheels facing the centre of the gearbox (so that the pinion and gear sit in a depression in the wheel, sort of like a typical west-coast style wheel with the spokes on one face).
Typically, in FRC applications, gears fail because the teeth are overstressed. (Other failure modes are possible.) The important characteristic is therefore the bending strength of the teeth.
There are a few ways of evaluating this, with varying levels of complexity and accuracy. The Lewis-Barth method is traditional and conservative, and requires relatively few parameters. AGMA has another method that takes fatigue and contact stress (another failure mode) into account, as well as a whole slew of other design factors—but you probably won't know what values to assign to them without some sort of basis for comparison. Given that bevel gears are a bit of an unusual system for an FRC application, I'd avoid relying on rules of thumb alone (so don't just take my word for it).
For an introductory reference, see this. Check out the literature provided by the manufacturer. Also, there's this: a whole book about gears, with a good explanation of the Lewis method. For more about the AGMA method, I recall that any recent edition of Shigley's Mechanical Engineering Design should include a chapter (written for upper-year mechanical engineering students). You might find this a convenient resource for equations and examples. Definitely search the Chief Delphi forums for other resources.
Unread 11-08-2011, 07:40
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
I suggest looking into worm gears, they can get you a lot more reduction in that space, and I bet it will be easier to find a set that small. with a worm gear you may be able to remove the cimplebox entirely.
Unread 11-08-2011, 23:18
Rookie Year: 1999
I'm not generally a fan of worm gears for drivetrains (see here, at page 30 for a discussion of low efficiency, especially as the reduction increases). However, seeing as you're only replacing a CIMple Box (4.67:1), and maybe part of the 4:1 bevel gear set (since I found a 2:1 set that might work for you), your total reduction is only around 10:1. With a well-designed structure and high-quality worm gear, you can probably achieve 90% efficiency on that reduction, which is quite competitive with spur gears. You'll probably need a stiffer structure to make it happen, though (alignment is critical with worm gears).
Unread 12-08-2011, 13:40
FRC #2220
Out of curiosity, with those 2:1 Bevels, the 5:1 Cimple box, and 3" wheels, what would a good FPS estimate be?
Unread 12-08-2011, 13:47
AKA: Isaak
Team Role: CAD
According to the JVN mechanical design calculator;
7 feet per second after frictional losses.
196 LBS of pushing force with rough-top tread.
Unread 12-08-2011, 13:52
FRC #2220
Is it possible to reduce the CIMple box further, I was hoping to get right around 10 FPS
