Re: Advantage to six wheel drive?
Regardless of axle setup, it is strongly advised to have two support points (bearings) to fully support the "beam". Whether they are in the wheel (notice all AM wheels take two coaxial ball bearings) or in the frame (even cantilevered WCDs have two bearings per axle)...doesn't matter. You don't want to put radial loads onto a single ball bearing.
So, I'll restate my thesis: Live-axle Mass = sprocket, hub(s), shaft, wheel, mounting screws Dead-axle Mass = sprocket, wheel, mounting screws BOTH approaches use at least two bearings... the Live-axle would have at least _two_ friction points at each end of the shaft... and the Dead-axle would also have _two_ friction points built into the center of the wheel from the two separate bearings residing in the center wheel hub-area... The mechanics of the Live-axle setup causes more friction/resistance at the bearings because of the angular pressures caused by the shaft pivoting inside the bearings as the pressures on the attached wheel (at far end of the shaft) change... times that resistance by six wheels... I KNOW these are _minute_ differences (or, are they?)... but, it's fun to think this through... HOW am I doing so far? Not bad for a former insurance-salesman, right? ;-) Last edited by Michael Blake : 12-08-2011 at 16:27. |
For a dead axle system, your axle is held by two plates, often inches apart, and any tolerance issues will make that shaft crooked and lead to extra friction on whatever is driving it. The double bearing issue you mention for live axle has always been a nonissue for us, our bearing blocks are one piece for the bearings and use the same hole. The load from the cantilever is higher, that is true, but it's still well within the spec of the bearing. We slammed down HARD in 2010 and didn't have a single issue anywhere, and our drive was still nice and low friction at the end of the season. I'd argue that few teams had lower friction drivetrains than us. If anyone wants to see our live axle drivetrain, check out my uploads. Our previous 5 robots are there, all using variations of the same system. |
Terminology Help needed???
The discussion here live axle vs. dead axle yet both options still powered wheels? I am sure I am wrong but, to me the term dead axle, lead me to believe a non-powered wheel. A simple bolt (axle) through the frame rails, with a wheel. No sprocket, chain or belt. For example the rear wheels on a front drive car are a dead axle. So here in FIRST does live axle = wheel fixed to the axle (power to axle), axle rotates in frame bearings--and dead axle = axle fixed to frame, yet wheel is powered? I guess if that is true, live or dead axles could be, or not be, powered? Thanks Troy |
Another advantage to dead axles is that they can be tubes, while live axles in the .5 inch range would be very difficult to make hollow. I think a lot of people think that live axles allow for better reliability, because the forces acting on a dead axle are always in the same orientation, they are more likely to fail due to fatigue, or bend (depending on the application).
Okay that makes sense. Thanks everyone!
Michael |
Jason |
#11
Think of 4 wheel drive as using a push lawn mower. You have to push down on the handle and lift the front wheelsvto turn it because otherwise it has a hard time turning. insert the middle wheel and the it will have a pivot point making it easier to turn
My team has never used live axles before, dead axles have always been the way to go for us. (except when we used maccanums) |
#12
Jason To anyone that doesn't know me personally: I have a habit of trying to consider all variables whenever possible. Sometimes this makes my work better then average, other times it makes it worse. I'll fully admit sometimes your better off ignoring something, it just becomes a betting game. Either way, I'm not much of a betting man. |
#14
