Go to Post But sometimes you just wanna build something that's MFD. - Andrew Schreiber [more]
Unread 14-08-2011, 14:45
Michael Blake's Avatar
Michael Blake Michael Blake is offline
Head Coach - FRC Under Development
FRC #6370 (Texas Titans)
Team Role: Leadership
Rookie Year: 2010
Michael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond repute
Re: pic: Don't do this. It's a bad idea.
Originally Posted by squirrel View Post
Here's a much better explanation.....but then, I do like old stuff
http://www.youtube.com/watch?v=F40ZBDAG8-o
NOW, _that_ was helpful... ;-) THANKS, Jim!!
"Retired Insurance Guy"
Link to me on this new fangled-thingy called The Linkedin and help make me popular, or at least appear to be... ;-)
https://www.linkedin.com/in/wmichael...ve_tab_profile
- Head Coach / Founder - FRC 6370 Texas Titans < FRC and VEX teams under development - VRC 15842a >
- President / Founder - San Antonio Competition Robotics Alliance - SACRA 501(c)(3) nonprofit (2012-present)
- Executive Director - Sports-Competition Robotics of Texas Excellence - SCRATE (2016-present)
- Former-Head Coach / Founder - FRC 3481 - Bronc Botz (2011-2016) // C++ Beta Test Team (2012 to 2016)
- Former-Lead Coach (2013-2016) Former-Head Coach (2009-2012) / Co-Founder - FTC 4008 - Bronc Botz (2009-2016) and FTC 4602 - Bronc Botz (2011-2016) and FTC 6976 - Bronc Botz-Nano for middle-schoolers (2013-2016)
- Co-Founder w/Matt Blake - VEX VRC 3481z - Wonder Botz (2011) [for Physically or Mentally Challenged Teens] (2011-2012)
Unread 14-08-2011, 14:35
Rookie Year: 2010
Originally Posted by EricH View Post
Short version: If both can go the same way at the same speed, both go the same way at the same speed. But if one of them can't keep that speed up, then it doesn't have to due to the way the differential is set up.
So, where's the "slippage" provided in this setup?
THANKS!
Unread 14-08-2011, 14:41
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
Why not choose pneumatic tires over the suspension? I don think you would get much "play" before the bevel gear bottoms out.
Unread 14-08-2011, 14:43
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Cuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond repute
Send a message via AIM to Cuog
THANKS!
There is no "slip"* in a differential. The nature of how the gears mesh is what allows the shafts to turn at differing rates. The differential itself has no control over the situation, its just along for the ride.
*(unless we start talking limited slip differentials and lockers etc)
KK4KQO
http://voltair.us
Too many projects, too little time.
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
THANKS!
In the differential gearing. Two of the 4 gears in the inner box are connected to the wheels; the other two are idlers. The relative speed of the wheels doesn't really matter to the idlers; they'll move as fast as they need to.
Hint: Think of this setup as 2 gearboxes. The inner box is the 4 in the middle of the "axle"; the outer is the bevel at the top and the large gear it meshes with.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 14-08-2011, 14:56
Rookie Year: 2010
Also, helpful... THANKS, Eric!
Unread 14-08-2011, 15:01
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Actually, Michael, lemiant didn't have a chance to read squirrel's link yet. I would suggest reading that link, then figuring out the drive system.
I hadn't. I thought the big bevel was attached to the shaft not the box. After reading that article I understand, and am amazed!!!!
Unread 14-08-2011, 14:19
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Wouldn't this work better with constant velocity joints (rather than universal joints)?
And are you using the universal joint as two of the members in a four-bar linkage that holds up the wheel? If so, isn't it just going to deflect to the maximum? (Or am I missing a spring somewhere?)
This would be a fun stock design to keep around...just to tempt people when FIRST decides to give us some real obstacles.
Unread 14-08-2011, 15:04
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
I Agree with your complaints about suspension geometry.
Also, The suspension on this seems to indicate a purpose of driving over varied terrain. With the completely open differential on there, the wheel with less resistance (often in the air, not making any contact) will get all of the rotation, leaving a torque on the static wheel equivalent to just the friction in the differential.
Unread 14-08-2011, 15:22
AKA: Isaak
Team Role: CAD
true, maybe you could use a limited slip differential to prevent that.
Unread 14-08-2011, 16:13
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
The suspension Appears to actually a three bar linkage with the link from the wheel bearing retainer to the differential frame being a spring loaded variable length link (possibly a gas shock). The u-joint is simply the joint between two links. It would benefit from more support, but the geometry should still work.
Also, by linking the axles with a slip clutch between the output gears of the differential the static wheel issue could be resolved. Like this. basically it's a primitive version of the limited slip differential.
Unread 14-08-2011, 16:58
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
That method of using the axle shaft as a suspension locating member was used on some IRS cars for years, including the Corvette starting in 1963
Unread 14-08-2011, 17:02
Cuog's Avatar
AKA: Alex
FRC #0422
Also known as a "Swing axle"
First on this list: http://www.autozine.org/technical_sc...uspension2.htm
Also used on VW Beetles(busses, and most other models including porsche) 38-68
KK4KQO
http://voltair.us
