Go to Post If only CD had a "like" button. - BrendanB [more]
Unread 08-15-2011, 04:23 PM
Techwiz's Avatar
Techwiz Techwiz is offline
Blake B
AKA: Blake
FRC #4909 (The Bionics)
Rookie Year: 2007
Techwiz will become famous soon enough
EasyJ 4 FRC
The Easiest Java Programming for FRC Robots
Hate Programming? Love Programming? Or Somewhere in between?
Well this is the tool for you!
Labview too complicated? Does Java and C's syntax hurt your fingers?
EasyJ is a system of draggable blocks that snap together. Each block has a section of code associated with it and when put in context with other blocks form a program.
Give it a try for yourself!
Make sure to check out the demos.
Learn More
Blake
Electrical, Programming and Design
Creator FRC Q&A 2017
Mass FRC Team 4909: The Bionics
Maine FRC Team 5122: The RobOTies (2014-2015)
Maine FRC Team 2648: Infinite Loop (2008-2011)
