Go to Post We know that the real goal of FIRST is not for this robot to win, but that we learn something. If i was on robotics to win, it wouldn't be nearly as fun. - Nin_estarSaerah [more]
Unread 19-10-2011, 17:19
Sconrad Sconrad is offline
AKA: Connor Young
FRC #0122 (NASA Knights)
Rookie Year: 2011
Sconrad is an unknown quantity at this point
Re: Advanced LabVIEW programming?
Originally Posted by JohnGilb View Post
Hello all!
I've got a question for you. Our team has been working with LabVIEW since it was available to FRC teams, and I think we've finally arrived at the point where we know how to make things work.
However, this is a very different thing from knowing how to make them work well. So, I'd like to ask you all in this forum - what techniques, design patterns, or features of LabVIEW do you use in order to make a really great robot?
(I heard there was a talk at the Championship this year along these lines, but I can't find any documents on it).
Here's what we've "discovered" (and note that some of these are probably pretty basic):
TypeDefs
Our team now makes liberal use of strict TypeDefs as interfaces between VIs. It's so much easier to add a new state to an enum or expand functionality by changing a TypeDef, and watching the changes ripple through your program.
Limited updates to Motors/Actuators
Using the feedback nodes (or a local variable, just something that stores information) we now only call the various incarnations of SetSpeed.vi if the input value has changed. This actually freed up a surprising amount of machine resources.
Program while expecting to fail
Any time we add a new feature that can be tweaked, we always create a control instead of a constant. Inevitably, at runtime, we discover something wrong, and it's far easier to tune a control than redownload the entire program.
Use of State Machines
The LabVIEW case structure makes programming state machines very easy, and FRC robots often have to accomplish all sorts of sequential tasks. Using a local variable or feedback node to control the current state makes the structure quite compact and easy to read.
Use the Profiler
The profiler that comes with LabVIEW is pretty powerful - it can be hard to read at first, but when you're trying to squeeze just a little more functionality out of the cRIO, knowing where you're bottlenecked is a significant help.
As far as I know (my second year on the team), we haven't had much trouble with the code overloading the cRIO resources in any way. However, compile/build time has been an issue. Some things that helped us were to avoid organizing code in subvis and avoiding while loops in teleop and autonomous (nested loops apparently are very difficult for labview to manage)
Unread 19-10-2011, 17:51
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
If you think this compile and build time is bad, go back to 2009 (the introductory year of the cRio and Labview for FRC).
You can minimize compile and build time by:
1. Using text files that read in constants that you use. You can FTP the text file, modify it, FTP it back, then have your code re-read it. This requires a little knowledge of the File I/O pallet and FTP, but it's a huge boon when you are tweaking things like autonomous.
2. Run the program from your laptop / computer rather than building it and deploying it. Use controls instead of constants. Once you've reached the right values, right click on the control and change it to default to your new value.
In fact, in 2010, the very first time we deployed code was the week of bag. Up until then we were always running from the computer while we updated it.
Labview handles loops just fine. The problem with using loops in Teleop and elesewhere is that the robot framework is already a giant loop that runs over and over again. The timing is tied into the driver station packet timing, and watchdogs monitor that your code is inputting and outputting often enough. If you have a loop in teleop and that loop takes some time to complete (we're talking more than around 1/20 seconds) you'll trigger the watchdogs. They assume something has gone wrong, and begin disabling functions on the robot for safety reasons.
Because Teleop is already one big loop, there's never really a reason to RUN a loop there. If you need something to loop more quickly, then use the period tasks (the area where the vision VI is put) in robot main.
