Go to Post It's not hard, it just requires thought. - Matt Leese [more]
Unread 27-08-2011, 16:27
Happy Birthday! davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Swerve Gear Box
If your team has made a swerve drive system in the past, did you use helical, bevel or worm gears to drive the wheel? Why did you come to that decision and how has it worked out for you?
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 27-08-2011, 16:46
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Re: Swerve Gear Box
I haven't made a swerve drive, but you missed a pretty big option. Containing the motor within the swerve module drastically simplifies the gearing. Definitely something to consider. See Wildstang.
Of teams who do go with a coaxial approach, the vast majority use bevel gears. I'll let people with more experience than me post reasons.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 27-08-2011, 16:47
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
Re: Swerve Gear Box
Originally Posted by Joe G. View Post
I haven't made a swerve drive, but you missed a pretty big option. Containing the motor within the swerve module drastically simplifies the gearing. See Wildstang.
Wouldn't that require more torque to rotate the gearbox because adding a motor onto the gearbox makes it much more massive.
Unread 27-08-2011, 16:48
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Re: Swerve Gear Box
Tell that to 111 and 71.
Unread 27-08-2011, 16:50
Joe G.'s Avatar
AKA: Josepher
Rookie Year: 2007
Re: Swerve Gear Box
Module rotational inertia is pretty trivial compared to frictional resistance to rotation. The larger disadvantages of the self-contained approach include physical size, difficulty in adding shifting capabilities if they are desired, and limits to the module's rotation generated by the motor's wires. But none of these come close to making this design unworkable, and they've been used on many fantastic swerve designs, as Andrew mentioned.
Unread 27-08-2011, 17:00
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
Re: Swerve Gear Box
Well, it seems like from looking through CD Media that most of the teams used bevel gears as opposed to helical or worm gears. Mechanically, it seems simple to produce. Is it harder than it looks to physically make? Programming an intuitive system is no problem. What was the biggest issues in controlling swerve for teams?
Unread 27-08-2011, 17:07
Joe G.'s Avatar
AKA: Josepher
Rookie Year: 2007
Re: Swerve Gear Box
Bevel gears require extreme precision in three dimensions. Both the top and side must be precisely machined, and you must have some way to precisely locate the bevel gears on the shaft. Definitely a job for machine tools. As a mental exercise, picture the number of ways a bevel gear's alignment can be "off," versus spur gear alignment.
Selection of bevel gears is another hurdle. Choosing an appropriate pitch, pressure angle, size, etc. is critical for good performance. Again, I'll let those with experience with these things elaborate further.
And even if you get it all right, bevel gears still create a noticeable drop in efficiency when compared to spur gears. Another argument for the self-contained approach.
Unread 27-08-2011, 17:12
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
Re: Swerve Gear Box
From what I have read, helical gears are more efficient than bevel gears, that is why they are using in car transmissions. But they do cost more than bevel gears.
Unread 27-08-2011, 17:15
Joe G.'s Avatar
AKA: Josepher
Rookie Year: 2007
Re: Swerve Gear Box
Helical gears are very efficient when used in a "straight" configuration, as spur gear substitutes. But when used as a crossed set, their efficiency drops dramatically, as low as 50%
Additionally, the primary reason for using helical gears in a car is their noise level. Helical gears have quite similar efficiencies to spur gears, but run much quieter, due to the more gradual engagement of the teeth.
Unread 27-08-2011, 17:14
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Swerve Gear Box
Programming an intuitive [swerve] system is no problem.
It's really really simple, unless you actually do it.
Unread 27-08-2011, 17:31
ratdude747's Avatar
ratdude747 ratdude747 is offline
Official Scorekeeper
AKA: Larry Bolan
ratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond repute
Re: Swerve Gear Box
especially if it is "unicorn drive". it can be made to work but trust me, it involves a LOT of code. (you would know...)
perhaps the worst part for ANY swerve is deciding how you want it to drive...
hence why I am more of a fan of mecanum than swerve for competition bots that strafe... if I am going to write a lot of code, I'd rather it be on my manipulator/camera tracking than on my drive code. that is, unless you pull a 148 and have crab and no manipulator (tumbleweed, 2008), which in that situation was nothing but epic...
for off season/fun, any swerve can be fun... or not fun... it depends on how you go about it.
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010, 2783 Engineers of Tomorrow 2011, Event Volunteer 2012-current
DISCLAIMER: Any opinions/comments posted are solely my personal opinion and does not reflect the views/opinions of FIRST, IndianaFIRST, or any other organization.
Unread 27-08-2011, 17:40
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
Re: Swerve Gear Box
Well, I see no problem with it because it's the off season. I am not constraint for time. Also, I still don't see how hard it can be. Just check each wheel if their velocity is within tolerance, if all the wheels are rotated with in the right tolerance and if they are not, make them.
PID loops are not hard. It is just all ratios, it just sounds hard. Sure, it is a lot of code, but it does not make it any harder. The hardest thing might just be incorporating a gyro scope, but that is not all that difficult unless there is a lot of inaccuracies in the readings.
Unread 27-08-2011, 17:43
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
Team Role: Leadership
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Re: Swerve Gear Box
You sound like all the people who say:
We will make our robot auto target stuff with the camera, its not that hard.
It doesn't seem hard, but it is. You can do it with enough time dedication and skill, but that doesn't stop it from being hard.
Unread 27-08-2011, 17:45
Ether's Avatar
Rookie Year: 1969
Re: Swerve Gear Box
I see no problem with it ...
I still don't see how hard it can be...
Just check each wheel...
PID loops are not hard...
It is just all ratios...
it just sounds hard...
that is not all that difficult...
You talk a good game, David.
  #15   Spotlight this post!
Unread 27-08-2011, 17:49
Joe G.'s Avatar
AKA: Josepher
Rookie Year: 2007
Re: Swerve Gear Box
When designing something complex, it is very important to have faith that you can do it.
However, do not confuse faith in your ability to overcome challenging obstacles, with the difficulty of the obstacles themselves.
Believe that you can do it, but believe that it will be hard, take a while, and throw unexpected challenges at you every step of the way.
