Belt Driven instead of Chain driven
Im not sure if this is legal for the wheels of the robot. But ive seen arms that use belts instead of chain which frankly seems like a better and cleaner installation than nocking out segments from 100 feet of chain. so can anyone help me out and tell me if its legal to have a belt driven drive train. Also your opinion on which is better
Re: Belt Driven instead of Chain driven
I have never done it personnaly but im sure its legal. Just after shipping this year a team put a picture up of their drivetrain, driven by belts instead of chain.
Whether or not it's better is a matter for debate. Belts need to be tensioned much more precisely, and can be a bit tricky to work with, since they can't be split like chain can. You need to plan things out ahead of time, and get exactly the size of belt you need. |
Long Answer: If the rules don't disallow something then go ahead. In the case of most years that means you can use whatever mechanical component for whatever purpose you want, as long as you are within the weight and cost limitations (note: there are lots more restrictions on electronics and pneumatics). Remember though, that just because it is legal does not make it a good idea, the reason most teams use chain is because they have decided it is best for them. There have been some threads comparing belts and chain. If you are interested in using belt, do some research. Last edited by lemiant : 31-08-2011 at 15:14. |
You may want to consider reading this white paper on chains vs. belts as you contiplate about which is better for you.
Belts require a much more precise frame, so I would never use belts with the kit frame. belts take up a lot more space than chain as well.
They do?
Belts are workable just like chain but they require a bit more thought and design than a standard 35 chain drivetrain to work. You also have to be careful with belt reductions to make sure you're not putting too much stress on the pulley teeth. |
We've used belts for our encoders, but so far never for our drive train, or even for our arm apparatuses.
My team hasn't done a belt drive, but there are some products out there that could simplify doing one. AndyMark sells a v belt pulley http://www.andymark.com/product-p/am-0592.htm. It was developed by team 1810. It is made in 2 pieces of plastic so that when you need to replace the belt, you just unbolt one side of the pulley and slip the belt on. And being plastic they are light, unlike the traditional pulleys. 1810 could tell you more.
There are also Link v -belts that you can shorten or lengthen yourself. You can also remove a link and thread them like you would a chain and reconnect them. Harbor Freight has some at http://www.harborfreight.com/vibrati...elt-43771.html. Grainger and IBT also have them. I haven't used these, but they look intriguing. I have no idea what kind of slippage they would have. If you want to go with the Gates Belts, they have a lot of videos to show you how at http://first.gatesprograms.com/video. My team was never organized enough to know what length we needed in time to order. I know every time I pick up the chain, I keep thinking about how wonderful it would be to shed those pounds. |
#10
This is key. The GT2 profile can take more than twice* the load that the standard tooth profiles can take.
The belts are well documented, and after you figure out what is important, the docs are not bad. You can easily check what belt width, and tooth counts will support what loads. *It could be even bigger than this. I haven't read the gates manual recently. |
#12
The most relevant piece here is comparing XL belt to 5mm gt2, pretty much identical belts in terms of size and weight. It's amazing the tooth profile makes such a difference. |
#13
Im Working on a chassis, and want to put belts on it. Where do I find Belts/pulleys for CAD and how do i buy them?
#14
This white paper does a good job of quantifying the bending problems on a standard 2010 robot. the frame bent enough to throw #35 (i think) chain, so belts would be out of the question. http://www.chiefdelphi.com/media/papers/2398 Last edited by Hawiian Cadder : 01-09-2011 at 18:09. Reason: forgot link to white paper. |
#15
Belts require more or less the same amount of precision that 25 chain requires. |
