Go to Post Don't be affraid of trying new things... Even if people say you are crazy, even if you get insulted, even if it involves a lot of time and money, try it. You can't know if it'll work or not if you didn't try it yet. - EDesbiens [more]
Unread 31-08-2011, 17:19
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
FRC #0973 (Greybots)
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
Re: Linear motion setup
You may consider using a basic 12v linear actuator. They will never achieve a speed of >1m/s, but then, thats fast for pneumatics. Motorized actuators essentially use a leadscrew powered by a motor which suits the load and speed needs.
Any of these actuators should suit your needs. I filtered the search to show high-speed actuators.
Also, they also present the cost benefit. These will probably never hit $200.
To control their position, you will need a sensor kit. I believe http://automationdirect.com sells them, don't remember the price. As to speed control, basic PWM will do the trick.
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
