Go to Post FIRST is just a single step in a multi-step process. Rome wasn't built in a day, and neither are solutions to the world's problems. - Tim Baird [more]
  #16   Spotlight this post!
Unread 04-09-2011, 19:14
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
Team Role: Leadership
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Re: Crab drive steering
Originally Posted by Ether View Post
I have no direct experience with "Monster Trucks", so your definition is a bit unclear to me.
Do you mean something like Figure 1?
or Figure 2?
or something else?
EDIT: This is just a guess, but from what he said I think he means the type in figure 1. (Not A)
  #17   Spotlight this post!
Unread 04-09-2011, 19:36
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Originally Posted by lemiant View Post
This is just a guess, but from what he said, I'm gonna say he means type A.
What's "Type A" ??
  #18   Spotlight this post!
Unread 04-09-2011, 19:47
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
Rookie Year: 1996
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
In our situation, because two wheels are linked, Ackerman angles cannot be achieved....so we're most like Figure 1. Because left and right drive are independent we do slow down the inside wheels with respect to turning angle.
A real monster truck is probably most like Figure 2.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
  #19   Spotlight this post!
Unread 04-09-2011, 19:57
Ether's Avatar
Rookie Year: 1969
It might be useful to facilitate possible future discussion in other threads if you could assign a unique name to your steering method.
Did you determine the relationship between the steering angle and the skid-steer compensation empirically or by analysis?
  #20   Spotlight this post!
Unread 04-09-2011, 20:36
AKA: Anthony Lapp
Rookie Year: 1996
Our algorithm was purely empirical. We set up a linear relationship between angle and "detuning" of the inside wheels.
More important to me isn't that we have Quadrasteer (formerly Monster Truck)...it's that you can access tank, crab and Quadrasteer from the same steering setup. Our control scheme uses two sticks on a PS style gamepad.
Tank:
Left stick up/down is driver side throttle
Right stick up/down is pass side throttle
Quadrasteer:
Left stick up/down is all wheels throttle
Right stick left/right is steering
Crab/swerve:
Right stick left/right is all wheels steer angle
Each of these modes is access by holding a top or trigger button....I prefer to have it setup as momentary.
Anthony Lapp
RobotOpen
  #21   Spotlight this post!
Unread 04-09-2011, 23:12
Ether's Avatar
Rookie Year: 1969
I'd be curious to know how your empirically determined speed reduction compares to a rough analysis I just did. See attachments.
I assumed that the center of rotation of the vehicle will be halfway between the points A and B.
Multiply the "outer" wheel speed by the fraction at the end of the analysis to give the "inner" wheel speed. L is the vehicle wheelbase, W is the trackwidth, and Ø is the steering angle, clockwise from straight ahead.
Name:	speed reduction sketch.png
ID:	10911  Click image for larger version
Name:	speed reduction analysis.png
