Go to Post words of advice: never tease your dad about his receding hair line. it will come back to haunt you. trust me. - Brandon Martus [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 05-02-2013, 09:38
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: [FTC]: Using Anderson Connectors for wiring.
Phil,
You are correct. I had forgotten the last sentence was added this year.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 05-02-2013, 09:44
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
No Problems...
Phil.
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
Unread 19-09-2011, 12:36
Pittwood Pittwood is offline
FTC #2888
Pittwood is an unknown quantity at this point
Hi Phil,
We thought we would try the Anderson 30 Amp connectors. Should we buy the unassembled or the permanently bonded? Also, the FIRST components list recommends a power distribution panel. Do you know what that is?
Thank you.
Ron Pittwood
Coach
FTC 2888
Unread 19-09-2011, 15:27
Unsung FIRST Hero
Rookie Year: 1996
Ron,
There is/was a power distribution panel for FTC in the past. I have been looking for it but haven't found it yet. It simply was a power terminal that connected the battery to multiple outputs. I believe that is what is referenced.
Al
WB9UVJ
www.wildstang.org
Unread 19-09-2011, 21:37
Michael Coleman's Avatar
Michael Coleman Michael Coleman is offline
Michael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of light
These PowerPole Splitters look interesting:
www.powerwerx.com/powerpole-power-distribution/ps-8-inline-8-way.html
www.powerwerx.com/powerpole-power-distribution/ps-4-inline-4-way.html
Unread 20-09-2011, 07:49
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Team Role: Leadership
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Lightbulb Re: [FTC]: Using Anderson Connectors for wiring.
Nice find Michael.
It appears that it is a common bus bar with power coming into any lead and being shared across all others. This is a nice way to put in future options for adding devices later. Start with the 4 bus version and then swap it out for the slightly larger 8 bus version.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 23-09-2011, 15:20
Scott_4140 Scott_4140 is offline
FTC #4140 (Fish in the Boat)
Team Role: Coach
Scott_4140 is just really niceScott_4140 is just really niceScott_4140 is just really niceScott_4140 is just really nice
So, the ruling states the we can use up to 30Amp Anderson Connectors. I can't believe there is anywere near this much current running through an FTC robot. The 15 Amp connectors greatly reduce the bulk of these connectors. The contacts are universal between the 15 and 30 Amp connectors, so you can use the larger 16 gage contacts for the folded over wire and still install them in the 15 Amp connectors.
Does anyone see a reason not to use the 15 Amp connectors?
Unread 23-09-2011, 15:53
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Yes. You risk failing inspection, because they're arguably illegal. (What is "similar"?)
It's at least plausible that FIRST had a technical reason for mandating the higher-current connectors—maybe they were especially (perhaps inordinately) concerned about durability, for example.
And even if it's just a mistake on FIRST's part, ask about it in the Q&A forum before deciding to use the 15 A versions.
Unread 24-09-2011, 20:50
ssi ssi is offline
AKA: David Spangler
FTC #2843 (Under the Son)
ssi will become famous soon enough
Actually, I think you are confused on the differences between the 15 and 30 amp connectors. According to this page:
http://www.powerwerx.com/anderson-po...owerpole-sets/
The 15, 30, and 45 amp connectors share the same housing, the only difference is in the contact.
The reason that FIRST specifies 30 amp connectors is probably because the battery is fused at 20 amps. It would be poor design to use a connector rated for less than the fuse on the circuit.
I hope this helps.
Unread 25-09-2011, 00:09
Unsung FIRST Hero
Rookie Year: 1996
David, I think your assessment is correct. The safety of the contact is an issue and the 15 amp contact is not the same as the 30 amp contact. The housing is the same for 15, 30 and 45 amp contacts. I also agree with Tristan, only the Q&A can make a firm answer on this point.
Al
WB9UVJ
www.wildstang.org
Unread 25-09-2011, 07:37
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
I just want to point out this section of the Powerwerx page:
High current rating, low resistance
The size of the wire a Powerpole contact will accept is the primary limitation of their ability to carry a load. The size of the flat contact area is actually the same for all 15, 30 & 45 amp contacts. Powerpoles will safely handle higher loads or surges, please read the PP30 data sheet (PDF) for additional information.
This is the information we worked with when using these connectors on our FRC robot. However as many others have said, only a Q&A post can be the final verdict.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 05-10-2011, 09:37
Sasha Sasha is offline
AKA: Alexander Kirillov
FTC #4137 (IslandBots)
Team Role: Coach
Sasha is just really niceSasha is just really niceSasha is just really niceSasha is just really niceSasha is just really nice
A couple of closely related questions:
- The rules say "Motor power, power and encoder wires may be extended by splicing additional lengths of wire" (R14<c>). Does anyone know if it allowed to just replace one of the wires (say, the power wire to the switch) with your own one - of course, of required AWG rating.
- The document about using PowerPole connectors specifically warns that you should NOT tin the wires. This is news to me: I have always tinned the wire end going into the screw terminals on motor controllers - it makes it so much easier to get in the hole. Any comments on this? Is there a real danger of the wire heating so much that the solder will melt?
