Go to Post My code mentors once told me, "A good programmer can look at a library, decide he hates it, and code everything from scratch. An amazing programmer can look at a library, decide he hates it, but realize the time it will save him and learn to use it." - slavik262 [more]
Unread 13-09-2011, 18:41
jhellr13 jhellr13 is offline
FRC #4272
Rookie Year: 2010
jhellr13 is an unknown quantity at this point
Java Code Help
Hey guys
I am the programmer on my team, and I am trying to make the transition to java from LabVIEW. I want to get make the labview code from last year into java so i can experiment. I am currently taking ap computer science, and have some knowledge of how java works, but not great at doing the code yet.I have the java code from an alumni from 2 years ago, but it a little too complex for me at this stage. I tried replicating this code for what our robot currently does, but I have no clue if it will work let alone if it is right.
I basically tried to make an arcade drive where the right joystick is the drivestick, and to make the arm operate on the left joystick as the y axis. The arm runs with a Relay. I don't have an autonomous, so i just left that blank. I also am unsure of how to make the dial on the bottom of the joystick control the speed of the drivetrain. It basically worked where if the dial was at the top, the speed was the highest, middle was middle speed, and at the bottom, the speed was low. I do not know how to implement this, if anyone can help.
If anyone can look over the attached code, it would be greatly appreciated. Any helpful tips or corrections would be a great help.
