Go to Post When someone asks me to define Gracious Professionalism, I'm just going to send them to AndyMark. - rsisk [more]
Unread 13-09-2011, 22:07
chi-town-biker chi-town-biker is offline
FRC #3135 (Robotic Colonels)
Rookie Year: 2011
chi-town-biker is an unknown quantity at this point
[FTC]: How to attach delrin to aluminum?
We’re talking about making a slider using 1/8” delrin sheets. But how do we attach it to aluminum channel? Normally I’d say glue it but the FTC rules only allow gluing plastic together. We could bolt it but the heads would extend above the delrin. Rivets?
Thanks
Unread 13-09-2011, 23:22
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Rookie Year: 2007
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Re: [FTC]: How to attach delrin to aluminum?
Thanks
There are a number of ways to do this, but how exactly are you using it to slide?
I would drill a hole in the channel and the delrin and then just bolt it on, but it seems to me like you are not going to have space for a bolt.
I just read the rules on the Hardware rules and it doesn't seem legal But I would asked this on the Q&A anyway.
If you used counter-sinking screw heads you could get the flat surface your looking for if you machined the sheet a little more.
And one last thing I can think of is, you can bend the delrin around and attach on the sides of this mechanism if possible.
Thats what I got for now
- Andrew
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 14-09-2011, 10:32
Rookie Year: 2011
Thanks for the reply. Let me clarify my original post.
We’re looking at using the slider as part of an elevator/forklift mechanism (ala http://www.chiefdelphi.com/forums/sh...Fforklifts%3F). I’m surprised that you think the rules do not allow delrin. I understand <R5> c. 1. (Any non‐reinforced polymer-based plastic sheet material may be used…) to allow delrin. The rule goes on to limit it to sheets 0.125” thick but does allow laminating it to form pieces up to 0.5” thick. We could laminate several sheets together and counter sink holes but we’re hoping there is a simpler solution that also avoids the bulk of laminated delrin.
Dave
Unread 15-09-2011, 16:31
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Rookie Year: 1998
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Is double-sided foam tape allowed?
Unread 20-09-2011, 12:30
Rookie Year: 2011
Thanks for your response. I’ve been having trouble posting a reply. I think because I’m new to posting and I’m still in posting probation.
We are discussing using the slide to as part of an elevator/forklift assembly (ala http://www.chiefdelphi.com/forums/sh...s%2Fforklifts). I was surprised when you said the rules may not allow using delren. My reading of <R5> c. 1. (Any non-reinforced polymer-based plastic sheet material may be used …) would allow it. The rule goes on to limit the plastic sheets to a thickness of 0.125” though we may laminate them together to a thickness of up to 0.5”. Tape is not allowed to hold pieces together.
The team has come up with two suggestions. 1) laminate the delrin and counter sink the bolt heads but we were hoping for a simpler way to attach the delrin to an aluminum frame without the bulk of laminated delrin. 2) From the data sheet, delrin melts at 350 degrees Fahrenheit. Rough up the aluminum, heat the delrin until soft, press the delrin on the aluminum and see if it fuses—not exactly simple but a thinner solution.
Does anyone have any other suggestions?
Dave
Unread 14-09-2011, 21:04
Rookie Year: 2011
We are discussing using the slide to as part of an elevator/forklift assembly (ala http://www.chiefdelphi.com/forums/sh...s%2Fforklifts). I was surprised when you said the rules may not allow using delren. My reading of <R5> c. 1. (Any non-reinforced polymer-based plastic sheet material may be used …) would allow it. The rule goes on to limit the plastic sheets to a thickness of 0.125” though we may laminate them together to a thickness of up to 0.5”. I guess we could laminate the delrin and counter sink the bolt heads but we were hoping for a simpler way to attach the delrin to an aluminum frame without the bulk of laminated delrin. Does anyone have any suggestions?
Dave
