Go to Post The robot is talking to you, you must listen to find out what might be wrong. - Al Skierkiewicz [more]
Go Back   Chief Delphi > Old Forum Archives > 1999
Unread 23-06-2002, 22:41
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
alliances
Posted by Austin Martus, Other on team #47 from son of pchs coach.
Posted on 4/26/99 7:00 PM MST
What FIRST should have done is come up with a way of in the qualifying you get points for what you've (your own team) has done instead or something like that. cause if you get *stuck*(paired) with a robot that is not very good(dont move or get on puck or anything) then youre screwed and have to do everything by you self which makes it 2 on 1 and really hard to get a lot of points and only have alliances(score for both) in the final rounds, but this would have to happen at the beginning of the year cause the building of a robot would depend on something like this
or some kind of rule like this
just a thought
also to make the finals more accurate to have a double elimination finals but the draw back is it takes much more time
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
[IMG] code is Off
BUCKEYE Alliances soap108 Regional Competitions 2 09-03-2003 12:59
Prebuilt alliances? archiver 2001 3 23-06-2002 23:56
Thank You! to our alliances from 'Aces High' Team 176 archiver 1999 0 23-06-2002 22:49
Thanks to all the great alliances out there lil devil Thanks and/or Congrats 1 07-05-2002 18:14
Both alliances sitting in endzone with 10 seconds left? Mike Soukup General Forum 7 24-03-2002 18:55
