Go to Post When you find yourself saying multiple times at one regional "...never coding at 1am in the hotel again... ...never again..." - BigJ [more]
Unread 14-09-2011, 23:23
Andrew Lawrence
Posts: n/a
Articulating tubes on roller claws
I know that I've seen teams articulate tubes to a desired angle, but they used 2 separate motors. Does anyone know of any way to accomplish the same thing but using only one motor?
Thanks!
Unread 14-09-2011, 23:33
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Re: Articulating tubes on roller claws
Thanks!
Yes, You connect the motor and one set of rollers to one output of a bevel gear differential and the other set of rollers to the other output. By locking the differential case in place, the rollers spin in opposite directions rotating the tube within the claw, by locking the two outputs together, the rollers spin in the same direction to intake or release the tube. Now the real challenge is working out how to lock the outputs to each other and the case to the claw.
Unread 15-09-2011, 00:03
Dillon Carey's Avatar
Dillon Carey Dillon Carey is offline
6wd swerve, it has been done
AKA: TinyHippo
FRC #1625 (Winnovation)
Rookie Year: 2007
Dillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond repute
An idea that we played with, but never really got working, was to have the top and bottom roller both connected to the same motor, using pulleys, but having the top roller geared somewhat faster. This makes it so you can suck the tube in, then continue to suck in and it will rotate up. Put a backstop so the tube can only rotate so far, and all you have to do is suck in till the tube hits the stop.
"More power 'till it breaks or you win."
- Keith Carey
Unread 15-09-2011, 00:09
Chris is me's Avatar
AKA: Pinecone
11's roller claw worked this way. Big wheels on top slightly tilted the tubes upward.
You're probably definitely going to need 2 motors to articulate a tube.
Unread 15-09-2011, 00:23
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
I think it could be done with one. It wouldn't be the most elegant solution, or the lightest, but I think it could be done.
What I'm thinking is something like a dog shifter, with a "forward" mode, a "reverse" mode with a second gear to reverse the belt, and a "neutral" mode (in between forward and reverse) for slower articulation. Alternatively, you could just have the "neutral" mode.
Now, if you want to count any servos used as motors, then yeah, that is 2 motors.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 15-09-2011, 01:01
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
Team Role: Leadership
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Well let's look at this. You want to be able to achieve 4 states:
------R
| <- (Pull Tube In)
-----R
------F
| (Push Tube Out) ->
-----F
------F
| (Rotate tube counter clockwise)
-----R
------R
| (Rotate tube Clockwise)
-----F
With a motor and a standard gearbox you have only two possible states Forward and Reverse. Similarly you have pneumatics with two states In and Out. In order to get 4 states using those devices you need at least two of them (2x2 = 4), many people on this thread have suggested novel ways of utilizing a servo or pneumatic in combination with a motor, however none are simpler than just using two motors.
The ONLY way you could do what you want using just one motor and nothing else would be to increase the number of possible states the motor can have. This could be done by creating a centrifugally shifting version of the gearbox that EricH recommended, for example. Such a gearbox would allow intake and output at high speeds and change its output to allow rotation at low speed. This is probably the WORST solution suggested to date as it is crazy complicated, but it is the only way to achieve what you want with just one motor.
tl;dr Use two motors!
- Alex
Unread 15-09-2011, 01:14
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
Originally Posted by PAR_WIG1350 View Post
...By locking the differential case in place, the rollers spin in opposite directions rotating the tube within the claw, by locking the two outputs together, the rollers spin in the same direction to intake or release the tube...
It sounds like a much more fun challenge if you limit the mechanism to using only one degree of actuation! I can think of a few approaches, but they all inevitably end up using more hardware than simply hooking up two motors to drive the rollers.
This was a good lesson we took from last year; if you minimize the degrees of freedom of a manipulator you can make a system that is in theory simpler than one that uses more actuators, but the final result typically ends up being more complicated than simply using multiple motors. Still, that won't stop us from trying... manipulators that utilize minimal actuators have a nice appeal.
Unread 15-09-2011, 07:13
Peter Matteson's Avatar
Peter Matteson Peter Matteson is offline
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Peter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond repute
The lightest simplest design is to use 2 motors in this case. Adding a linkage or switching system adds complexity and failure points. This is a case of bad engineering practice. Remember just because you can make something doesn't mean you should. Complex mechanisms like that have been the downfall of more FRC robots than anything else over the years.
2011 Championship Finalists/Archimedes Division Championships w/ 2016 & 781
2010 Championship Winners/Newton Division Champions
Thank-you 294 & 67
2009 Newton Division Champions w/ 1507 & 121
2008 Archimedes Division Champions w/ 1124 & 1024
2007 Championship Winners/Newton Division Champions w/190, 987 & 177 The Wall of Maroon
2006 Galileo Division Champions w/ 1126 & 201
www.bobcatrobotics.org
"If you can't do it with brains, it won't be done with hours." - Clarence "Kelly" Johnson
Unread 15-09-2011, 09:01
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
If you want to arbitrarily orient the tube, then two motors is the simplest option.
But I would argue that there is not a lot of value in being able to arbitrarily rotate the tube, in and of itself. Typically, there is one orientation you want those tubes to be in when you go to score. So being able to rotate the tube is only useful in that you can bring any tube you pick up or are carrying to that orientation.
If getting the tube you picked up into your desired scoring orientation is your goal, there are several one-motor ways to make it happen. You can design your roller claw such that the geometry forces tubes to be sucked in to the correct orientation.
Unread 15-09-2011, 09:54
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
340's roller claw this year oriented tubes pretty consistently from what I saw at Chesapeake. They used one motor (I think) and a series of rollers to suck tubes in while also turning them to vertical. Here's a picture for reference: http://www.chiefdelphi.com/media/photos/36576
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
