How to set up a 3rd (non drive) motor in C++ Windriver
I'm relatively new to programming in C++ and i have a question regarding how to set up a third motor for say arm control. I am using the default Simple Robot Template in windriver. I already understand how to set up tank and arcade drive but as this 3rd motor will only be used for arm control and not driving I'm hesitant to reuse those commands. The biggest problem I am having right now is figuring out how to take a joystick input such as a get-Axis or something like that and send the information to a motor or speed controller. Thanks in advance.
Re: How to set up a 3rd (non drive) motor in C++ Windriver
I suggest looking into the Jaguar, Victor, and Relay classes. As for the get-axis stuff, I'm pretty sure the Joystick class has a GetAxis method that returns x, y, or z axis(though many don't have a z-axis), though the translation between joystick and pwm output is up to you.
Thanks for the info I'll look into it.
From my fuzzy memory...
Among your member variables: Jaguar* pMotor; In the body of your constructor pMotor = new Jaguar(...); // I don't remember the specific parameters. One will be the slot your sidecar comes out of, one will be the PWM output the motor is connected on In your operator-control code: pMotor->Set(0.5); // partial forward. I may have gotten the function name wrong. Check out the .h file for details. |
WPILib will become your greatest friend, it has everything you need to know to program the robot.
if you're looking to use an axis as your motor control:
1. joystick(whichever joystick you're using).GetRawAxis(#), i can't remember the axis numbers but if you do a print statement, for all the different axis. 2. look into using a encoder or potentiometer (feedback) thus you can use a pid loop. for more info about pid loops, check: http://www.simbotics.org/resources/controls 3. joystick tips, use a limit function to limit the output of the joystick. also a dead band function helps with the problem that most joysticks don't go back to zero often or at all |
{ //First weed out numbers not in range int Number=(int)nr; Number-=m_StartingPort; bool ret=false; nr++; //DOH the number selection is cardinal! ![]() if ((Number>=0) && (Number<m_NoJoysticks)) { memset(&Info,0,sizeof(JoyState)); //zero the memory //The axis selection is also ordinal Info.lX=m_ds->GetStickAxis(nr,1); Info.lY=m_ds->GetStickAxis(nr,2); Info.lZ=m_ds->GetStickAxis(nr,3); Info.lRx=m_ds->GetStickAxis(nr,4); Info.lRy=m_ds->GetStickAxis(nr,5); Info.ButtonBank[0]=m_ds->GetStickButtons(nr); ret=true; } return ret; } This is the code I use to obtain the Joystick values... The axis are x, y, z position followed by x, y, z rotation (these enumerations match Microsoft's DirectInput sdk), and my info structure is the same as direct input. Once you get these values you can manipulate them... the range is -1 - 1.0 on the axis ... here are some of my axis params IsFlipped - Apply a -1 scalar Multiplier - Apply a scalar FilterRange - apply a deadzone range isSquared - square the input (this is used more times than not) Here is what I do: if (AnalogEvents) { //Now to use the attributes to tweak the value //First evaluate dead zone range... if out of range subtract out the offset for no loss in precision //The /(1.0-filter range) will restore the full range double Temp=fabs(Value); //take out the sign... put it back in the end Temp=(Temp>=key.FilterRange) ? Temp-key.FilterRange:0.0; Temp=key.Multiplier*(Temp/(1.0-key.FilterRange)); //apply scale first then if (key.isSquared) Temp*=Temp; //square it if it is squared //Now to restore the sign Value=(Value<0.0)?-Temp:Temp; std::vector<std::string>::iterator pos; for (pos = AnalogEvents->begin(); pos != AnalogEvents->end(); ++pos) m_controlledEventMap->EventValue_Map[*pos].Fire(key.IsFlipped?-Value:Value); } You may want to ignore the event firing lines except to say that the event value map will do a map (i.e. log-n) search for the events associated with an input and fire them... I do this because it allows me to easily switch axis assignments etc. Ideally the code is more robust if you do not hard wire the controls directly to object that listens for event changes. Now then in the main I do the following: void OperatorControl(void) { printf("Starting TeleOp Session\n"); m_Manager.ResetPos(); //This should avoid errors like the arm swinging backwards m_Manager.GetRobot()->SetUseEncoders(false); m_Manager.SetAutoPilot(false); //we are driving the robot double tm = GetTime(); m_Manager.SetSafety(true); while (IsOperatorControl() && !IsDisabled()) { double time=GetTime() - tm; tm=GetTime(); m_Manager.TimeChange(time); Wait(0.010); } } I make one call to a TimeChange(time) which then dispatches to poll the joystick and fire off the events. The robot class (the class that processes the events) will then call: void Robot_Control_2011::UpdateVoltage(size_t index,double Voltage) { switch (index) { case FRC_2011_Robot::eArm: { //Note: client code needs to check the levels are correct! m_ArmMotor.Set(Voltage); //always the same velocity for both! #ifdef __ShowPotentiometerReadings__ DriverStationLCD * lcd = DriverStationLCD::GetInstance(); lcd->PrintfLine(DriverStationLCD::kUser_Line4, "ArmVolt=%f ", Voltage); #endif } break; case FRC_2011_Robot::eRollers: m_RollerMotor.Set(Voltage); #ifdef __ShowRollerReadings__ DriverStationLCD * lcd = DriverStationLCD::GetInstance(); lcd->PrintfLine(DriverStationLCD::kUser_Line4, "RollerVolt=%f ", Voltage); #endif break; } } Where these are defined as such: Victor m_1,m_2,m_3,m_4; //explicitly specify victor speed controllers for the robot drive RobotDrive m_RobotDrive; Victor m_ArmMotor,m_RollerMotor; We use victor speed controllers! You'll need to know what you use to get the best reading derivative when the floating point gets translated to integer values. On a side note: the robot drive we use the constructor that allows you to explicity specify what controllers you want to use since the default case assumes you have Jaguar speed controllers. Here is a snip of how to do that: Robot_Control::Robot_Control(bool UseSafety) : m_1(1),m_2(2),m_3(3),m_4(4), m_RobotDrive(&m_1,&m_2,&m_3,&m_4), //m_RobotDrive(1,2,3,4), //default Jaguar instantiation m_ArmMotor(5),m_RollerMotor(6),m_Compress(5,2), Note: that for the arm Victor, the contructor use shown here assumes the digital side car is hooked up to slot 4 in the cRio. The first parameter shown indicates which channel on the digital side car that you are using. I realize this presentation could be over-whelming, so feel free to ask more questions. ![]() |
which makes what you did into significantly less code for someone new to programming... it also makes it a lot easier... and less time consuming... which gives you time for the programming autonomous, which has factor for winning matches in FIRST for 4 of the past 5 years... |
THANKS for your help! |
#10
In Breakaway, autonomous was not as key, but was useful. In lunacy, autonomous' purpose was to get away from they human players. if you didn't drive away, you could count on the human player filling your trailer to the top. In overdrive, you got points for knocking the off the trackballs and driving around the field. In rack 'n roll the keepers were scored only during autonomous (similar to ubertube) and over-rode any scoring on that peg at any point in the match (always red/blue) based on the importance of autonomous this previous season, i don't this first will ease up on the scoring involved with this portion. the autonomous usually could make or break matches. and usually the sensors that make autonomous easier usually make driving the robot easier. |
#11
What resources are you referring to in particular? Let us see the significant less code you mention... I've showed my cards... let's see your hand. ![]() We may all learn something from this. |
#12
i am referring to the wpi library that is given to all frc teams. it includes code for the joysticks, sensors, and so on. pretty much if you put a sensor on your robot, there is code made and debugged for it. which pretty much leaves you to only have to deal with the code in myrobot.cpp and myrobot.h
#13
i'm just saying your time would be better used during the season using the library... especially if you want students to learn to program. you'll loose all your new people pretty quickly without the use of the library. off season is fine, but if you don't make programming fun for the new people, they won't stay interested when you get to the headache moments. the best thing is to have them just program the myrobot files and look at the wpi library to try to understand how the function works, if they're interested in how the functions. but writing that stuff during the season will leave you with no time and an arm that moves inefficiently by dead reckoning. now as a mentor you can write this stuff yourself in your free time or working on another computer while they're working on the myrobot files. we created our own pid this past season but that was my mentor's doing, this was to make our pid work better for our uses. just some suggestions... this is after all a program for learning and mentoring... you might be surprised the functions some of these students come up with
#15
http://www.termstech.com/articles/Autonomous2.html http://www.termstech.com/articles/PID_Kalman.html One thing I regret is that I didn't spend more time writing an article to answer this question that goes more into some of the coding principles like top-down design bottom up implementation, and show a high level design of how the pieces fit together. I still may do this in the future, but there is so much other work I need to tend to (all within the robotics realm). |
