Go to Post During the year I can't wait for the game hint to be released, but then as soon as it is released and I read it for the first time my head starts to hurt and I regret reading it at all... - Jon Jack [more]
Unread 25-09-2011, 14:34
computerish computerish is offline
FRC #0619
computerish is an unknown quantity at this point
Can FTP to robot, Netbeans can't
Earlier today I was able to download and run code on the robot with no problems. Netbeans suddenly stopped being able to connect to the robot, though. I can still ping both the router (on the robot) and the cRIO. I can also FTP to the cRIO with FileZilla. This is the Netbeans output:
Code:
init:
init:
Deleting directory C:\Users\carobotics\Documents\NetBeansProjects\FootballRobot2\build
Deleting directory C:\Users\carobotics\Documents\NetBeansProjects\FootballRobot2\suite
Deleting directory C:\Users\carobotics\Documents\NetBeansProjects\FootballRobot2\j2meclasses
clean:
Created dir: C:\Users\carobotics\Documents\NetBeansProjects\FootballRobot2\build
Compiling 2 source files to C:\Users\carobotics\Documents\NetBeansProjects\FootballRobot2\build
compile:
Created dir: C:\Users\carobotics\Documents\NetBeansProjects\FootballRobot2\j2meclasses
preverify:
Created dir: C:\Users\carobotics\Documents\NetBeansProjects\FootballRobot2\suite
Building jar: C:\Users\carobotics\Documents\NetBeansProjects\FootballRobot2\suite\FootballRobot2_1.0.0.jar
jar-app:
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[translating suite image [closed: false, parent: squawk] ...]
### Excluding compile: com.sun.squawk.Method::getParameterTypes
### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
[Including resource: META-INF/MANIFEST.MF]
Romizer processed 90 classes and generated 4 files.
Expanding: C:\Users\carobotics\Documents\NetBeansProjects\FootballRobot2\suite\FootballRobot2_1.0.0.jar into C:\Users\carobotics\Documents\NetBeansProjects\FootballRobot2\suite
Moving 1 file to C:\Users\carobotics\Documents\NetBeansProjects\FootballRobot2\suite
Deleting: C:\Users\carobotics\Documents\NetBeansProjects\FootballRobot2\image.suite.api
Host OS: Windows 7 6.1, 6.1
Host JVM: Java HotSpot(TM) Client VM 19.0-b09
Target IP: 10.6.19.2
Network interfaces on host:
    NETGEAR WN311T Wireless PCI Adapter:  address: 10.6.19.6 netmask: 255.255.255.255 or hidden by IPv6 address (due to Java on Windows Bug:6707289)
Connecting FTP @10.6.19.2
Remote OTA server does not match, upgrading
C:\Users\carobotics\sunspotfrcsdk\build.xml:95: The following error occurred while executing this line:
C:\Users\carobotics\sunspotfrcsdk\ant\upgrade.xml:40:
org.apache.commons.net.ftp.FTPConnectionClosedException: Connection closed without indication.
        at org.apache.commons.net.ftp.FTP.__getReply(FTP.java:267)
        at org.apache.commons.net.ftp.FTP.sendCommand(FTP.java:460)
        at org.apache.commons.net.ftp.FTP.sendCommand(FTP.java:520)
        at org.apache.commons.net.ftp.FTP.port(FTP.java:849)
        at org.apache.commons.net.ftp.FTPClient._openDataConnection_(FTPClient.java:477)
        at org.apache.commons.net.ftp.FTPClient.__storeFile(FTPClient.java:388)
        at org.apache.commons.net.ftp.FTPClient.storeFile(FTPClient.java:1388)
        at com.sun.spot.sdk.tool.ftp.UpgradeTask.upgrade(UpgradeTask.java:317)
        at com.sun.spot.sdk.tool.ftp.UpgradeTask.execute(UpgradeTask.java:216)
        at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291)
        at sun.reflect.GeneratedMethodAccessor65.invoke(Unknown Source)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
        at java.lang.reflect.Method.invoke(Method.java:597)
        at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
        at org.apache.tools.ant.Task.perform(Task.java:348)
        at org.apache.tools.ant.Target.execute(Target.java:390)
        at org.apache.tools.ant.Target.performTasks(Target.java:411)
        at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1397)
        at org.apache.tools.ant.helper.SingleCheckExecutor.executeTargets(SingleCheckExecutor.java:38)
        at org.apache.tools.ant.Project.executeTargets(Project.java:1249)
        at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:442)
        at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget.java:105)
        at org.apache.tools.ant.Project.executeTarget(Project.java:1366)
        at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
        at org.apache.tools.ant.module.bridge.impl.BridgeImpl.run(BridgeImpl.java:281)
        at org.apache.tools.ant.module.run.TargetExecutor.run(TargetExecutor.java:539)
        at org.netbeans.core.execution.RunClassThread.run(RunClassThread.java:154)
BUILD FAILED (total time: 57 seconds)
