Go to Post Don't short change your drivers. They really need drive time. - Joe Johnson [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Thread Tools Rating: Thread Rating: 100 votes, 4.96 average. Display Modes
Unread 26-09-2011, 20:29
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
CAD - Gates Belts Sprockets
I am currently working on CADing the belt drive part of my chassis. However i cant find any CAD's of Gates sprockets. I specifically need the 20 tooth Sprocket from gates. Can someone direct me to the right place?
THANKS
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 26-09-2011, 20:52
R.C.'s Avatar
Happy Birthday! R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Re: CAD - Gates Belts Sprockets
What type? Pitch?
-RC
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 26-09-2011, 20:56
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
For modelling purposes, I've been using the pulley CAD models that you can get from SDP/SI's catalog: https://sdp-si.com/eStore/Direct.asp?GroupID=217
Click on the part number and then "3D CAD Models".
Unread 26-09-2011, 22:45
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
FRC #0973 (Greybots)
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
I must admit, I do exactly the same. Their parts library is extraordinarily extensive. If you are not submitting your CAD under the requirement that everything is an original model, I see no reason as to why you might not use a CAD library.
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 26-09-2011, 22:47
AdamHeard's Avatar
Lead Mentor
In terms of effective design, it makes no sense to redraw a part that's already good to go. That's taking time from the truly important tasks that CAD is used to accomplish.
Unread 27-09-2011, 21:56
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Last spring I ended up using the cad model from the B&B Manufacturing web page, which is also where we bought more from: http://catalog.bbman.com/db/service?...=2 0-5M15M6A8 which I found based on a search for the part number given in the KOP documentation or what was on the package we received the pulley in, can't remember which anymore.
I've also switched over to using the models from the SDP/SI website for the stuff I'm playing with this fall, since they have a very good library. I have not found any difference between the models I got from the two sites. The SDP website requires you to drill down to what you want in their parametric selector, there is no way to search using a competitors part number. Also, the prices at SDP are a little higher, at least for the 20 groove pulley, than at B&B. I also noticed that size is out of stock at both websites tonight.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
