Team 3647: Off season
Team 3647's redesigned robot, The Guillotine, for LogoMotion.
http://www.youtube.com/watch?v=3RnBf0_tKAg This was us doing Auton/Driver practice in 2nd building; the ceiling was too low so we did not have the top pegs. We are using line sensors for the Auton, and currently working to make it faster. The video was taken the Friday night before Fall Classic; we will also be going to the Battle of the Border in SD on the 15th. |
Re: Team 3647: Off season
Great robot guys!
It was a pleasure working with you guys. The way you played made it apparent that you have practiced hard! Thanks for your partnership in the final elimination matches! See you at Battle at the Border next month! |
Thank you for the kind words, it was great working with you guys also and meeting you. And thanks for picking us for your alliance, the final run was great.
See you in at Battle at the border! |
Looks like a good bot, and a very good autonomous mode, I'm sure you'll be able to score consistently with that!
One piece of advice to your team, your kit wheels in the back seemed to be slipping a lot on the carpet, especially when you turned. Best advice for that is to invest in some High-Traction wheels ("Plaction Wheels," available at http://www.andymark.com/category-s/103.htm ) My team's used these for the past 6 years now (except for Lunacy!) with a lot of success, we definitely like these wheels because the rough top tread DOES NOT SLIP! If you were to throw a pair of these on your bot to replace the kit wheels, I think you'll find you'll be much faster and far more nimble. Either way, best of luck to ya! |
Very interesting lift! Any details/pictures?
Very impressive for a rookie team to go all out for the offseason! Really cool stuff. Keep it up.
I'm really glad that you guys are continuously improving your robot and going to offseasons, you have the right ideas for a rookie team. Keep it up.
Let us know how well you do in the off season comp, and good luck! |
#10
Another alternative I've seen is using threaded inserts with pre-drilled tread (so that the holes in the tread line up with the inserts). |
#11
Might I inquire as to what the big grey storage tank looking object on the back was? Hazarding a guess, I would say it looks like a pneumatics reserve tank. A very large one.
I also like the sheer accessibility your electronics board has. The orientation, as well, looks like less back pain from spending so much time hunched over 90 degrees to look at one. On a final note, I'm noticing this more in your elevator than others, have you ever tried blocking a thrown tube with it? It looks like the "wall" that extends up might just be able to do such a task. All in all, looks like an amazing bot, and I applaud you for constantly striving to better your team, even after competition season is over. |
#12
Yes, even though that wasn't necessarily what I was thinking about when I put it there... it is convenient to access and we never had a problem with it being damaged during game play. That is an interesting game idea, we haven't thought of it. I guess it could work if we parked right in front of the lanes. Though I am not sure if would be considered GP in game play. Last edited by Mk.32 : 04-10-2011 at 23:38. |
#13
Very nice bot! How much does it weigh? Also, how's the 4 WD with the AM trick wheels working out for you? It seems nice.
#14
You guys should find a way to make it up to the madtown throwdown event in Novemeber.
I expect big things in 2012 from you guys. |
#15
The 4WD generally works well, there is a problem of a lack of traction in the back wheels, as you can still in the video. But we will try out some tread-ed wheels. We would have gone 6 wheel, with the dropped center, but the supports for the tower/cylinder conflicted with the placement of the 6th wheel. We would love to go, but for us that would mean a 6 hour drive... However we will be at BATB. on the 15th. |
