Go to Post What's this about a robot that they speak of? Are we supposed to build one???? - ryan_f [more]
Unread 29-09-2011, 16:34
AndrewD's Avatar
AndrewD AndrewD is offline
Programming/Electrical Mentor
AKA: Andrew Dolio
FRC #1243 (Dragons)
Rookie Year: 2010
AndrewD is an unknown quantity at this point
Driver Station I/O in C++
Hello all,
I'm trying to read buttons from the cypress board to fire relays on the 'bot.
My code so far (just for the relays and dsio) is:
Code:
class RobotDemo : public SimpleRobot
     Relay barrel1;
     Relay barrel2;
     Relay barrel3;
     DriverStation ds;
public:
     RobotDemo(void):
          barrel1(3),
          barrel2(4),
          barrel3(5),
          ds()
           GetWatchdog().SetExpiration(0.1);
     void OperatorControl(void)
          GetWatchdog.SetEnabled(true);
          while (IsOperatorControl())
               GetWatchdog().Feed();
               if (ds.GetDigitalIn(3)) {
                    barrel1.Set(Relay::kOn)
               } else {
                    barrel1.Set(Relay::kOff)
of course there is more code for the drive train but this is all that needs help. i need to know what to put in the parentheses for "ds()" under "RobotDemo(void):"
Thanks in advance,
Andrew D.
____________________________________________
FRC Team #1243 - The Dragons
Unread 29-09-2011, 17:53
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Re: Driver Station I/O in C++
If I did not know WPILib, your question is already answered (that is where you put the parens). However, I do know WPILib, and you are initializing the ds wrong (because you are getting an error you did not post, which are helpful, no matter how odd it may seem to you). The DS is a singleton, and so you need to initialize it based on the singleton. If you looked at the WPILib docs, you would notice the constructor is private.
Code:
     Relay barrel3;
     DriverStation &ds;
public:
     RobotDemo(void):
          barrel1(3),
          barrel2(4),
          barrel3(5),
          ds(*(DriverStation::GetInstance()))
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
