Re: 2012 Queen City FRC Regional
As the numbers of viewers are increasing, the feed is becoming increasingly unwatchable. Anybody else with this problem?
WOW. Semifinals between 71-1024-3494 and 45-3940-781 is probably one of the best matches in the entire regional. |
How was that not a Red Card? 1038 was literally ON the red bridge in the middle of the triple balance attempt!
A valiant effort from 3301, 2481, and 829. Last edited by Jared Russell : 07-04-2012 at 15:33. Reason: EDIT: Wrong team numbers; Softening language |
You mean the 829 alliance? Someone explain this bridge thing to me please?
I apologize for adding to the confusion by listing the incorrect team numbers; it's fixed now.
Very tough call for the refs in Queen City in that semi final match. It appears a valid triple balance defense is to just park in front of the bridge and let your opponents push you up.
-Brando Last edited by Brandon Holley : 07-04-2012 at 15:22. |
Should have been at a minimum a technical foul. The definition/interpretation of "interfering with the act of balancing" is hazy in this situation. The third robot was not on/touching the bridge so I would not interpret them as in the act of balancing. The other two robots however were on the bridge and could be argued were actively trying to balance.
EDIT: I'm surprised this is the first time this has happened (that I know of). Last edited by Deetman : 07-04-2012 at 15:23. |
([G25] is the touching an opposing bridge/interfering with balancing foul) |
The other semifinal 2481, 3301, 829 vs 3193, 1038, 48 was the most intense match yet. The defense was so hard that 3193 ended up on the other alliances bridge! |
#10
Apparently you can now drive on the opponent's bridge during a triple balance and only get a 3 point penalty...
#11
Ok, so for those of you that didn't see the play: 2481 + 3301 were both on the red bridge. 1038 was playing defense by the red bridge. 829 was attempting to get over to the red bridge to balance, but 1038 was playing defense on them. During the playing of defense, 1038 got sandwiched between the red bridge and 829, who was straight on facing the red bridge ready to drive on . 829 pushes 1038 and they hit the corner of the bridge. No foul called. 829 backs up and gets more situated to get onto the red bridge. As 829 drives forward, they literally push 1038 onto to the red bridge. I didn't see any ref's call any foul, and the posts here make it sound like just a 3 point penalty was called, and i don't know what the 3 point penalty is for. 829 was clearly trying to make it a triple balance and 1038 interfered by getting onto the bridge. In my opinion, 829's alliance should be in the finals. Why? A couple of reasons. Quote:
Conclusion: It doesn't matter if 829 was in the act of balancing, because 1038 made contact with another red robot that without question, was trying to balance. Still should be a triple balance. ------------------ Supposedly you're not interfering with the act of balance if the balancing robot isn't touching the bridge, even if the defensive bot is. If this stands legal, i know what I'm having my alliance's defensive bot do. -Duke Last edited by Duke461 : 07-04-2012 at 15:31. |
#12
It was 1038.
[G28] states that "Robots may not touch an opponent Robot in contact with its Key, Alley, or Bridge." The penalty is a technical foul (9 points) plus a yellow card. [G25] states "Robots may not contact or otherwise interfere with the opposing Alliance Bridge." The penalty is a technical foul along with a red card. Isn't that 1038 did? I'm going on a limb and saying the refs made a very bad call. Last edited by bam-bam : 07-04-2012 at 15:31. Reason: Citations |
#13
The relevant rule is this:
Forgot about [G44]. By the letter of the rules it does appear the correct call was made as 1038 would never have ended up on the bridge themselves.
Given the point trade off, if the right call was truly made this may become more common... |
