Go to Post Powerhouse teams aren't powerhouse because they build great robots, they are powerhouses because they build great teams. - couvillion [more]
Unread 01-10-2011, 17:13
robertsun robertsun is offline
FRC #0488
robertsun is an unknown quantity at this point
[FTC]: Reed Switches And HiTechnic Prototype Board
The rules allow for a HiTechnic Prototype board and ANY Compatible sensor...
That means we can basically use any sensor we want?
How about reed switches?
Have any experience?
What type works?
Thanks
Unread 01-10-2011, 23:41
Michael Coleman's Avatar
Michael Coleman Michael Coleman is offline
Michael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of light
Re: [FTC]: Reed Switches And HiTechnic Prototype Board
Reed switches with exposed glass envelopes would probably not be permitted per rule <R3>c. Broken glass on the field would likely be considered a hazard.
This is a good question for the FTC Q&A forum if you want to be certain.
Unread 03-10-2011, 00:19
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Sensors appear to just be the tip of the iceberg:
Originally Posted by FTC Q&A forum
Originally Posted by FTC4494
Is it legal to use an arduino-type microcontroller (or any other microcontroller/IC for that matter) to process signals on the NXT prototype. I understand that I am limited by the power from the prototype board, and that there is no i2c or other serial communication available on the prototype board.
A: There is nothing in the rules that prohibit it provided that all other portions of Rule <R5>d are followed.
I would have to agree that the glass encapsulated reed switches might be ruled a hazard, but non-glass reed switches should be fine provided no rules are broken in the implementation, but you should Q&A it just to be sure.
