Go to Post And I have to say, those days where you are just beating yourself, and smacking your head against the wall, and you just wish the robot would catch fire so you could go home, make the top of the mountain that much sweeter. - Gboehm [more]
Unread 04-10-2011, 01:19
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
pic: Chains - They are possible in SW
Unread 04-10-2011, 01:21
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
Re: pic: Chains - They are possible in SW
Care to share how you did that? Every time I model chain it causes a ton of system crashes (my computer is probably to blame there, unless there is an automated tool that I dont know about). What mate did you use, the path mate works ok, but mating every piece gets tedious, Is there an auto mate tool that I am unaware of?
Unread 04-10-2011, 02:00
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
FRC #0973 (Greybots)
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
Forgive me for whatever Inventor terminology I might use. I am a dedicated Inventor user.
A question- Is the chain a Flexible Design Accelerator? In the sense that the constraints allow the links to mesh with the sprocket effectively and consistently?
In other words, I'd probably have no problem modeling the chain as an assembly. The goal would be to get the chain to be actually functional.
Thanks.
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 04-10-2011, 12:37
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Nice work! The rendering is beautiful--I thought it was a photo, so I had to look back and really check out the detail when you said it was CAD. I love the droop in the chain!
What version of SW is this?
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 04-10-2011, 20:40
The CAD Guy
Sadly it is not functional. I've yet to figure out how to do that, though I will be trying over time.
In SolidWorks there is a Chain/Belt Tool. I used that, then copied the sketch and put it in its own part file. I then dropped the part files for the two different types of links. (Inner link and outer link) I constrained them to the sketch line. I then used a "Curve Driven Pattern" to pattern them around the sketch curve. (Make sure to make them tangent, otherwise they won't curve round the bend) I then "deformed" the sketch adding arcs in order to get the correct amount of links to fit right, and added the half link to save space. It wasn't an "exact" science, but it would definitely tell you how make chain links you need. No more guessing.
I then saved it as a part, and just constrained it to the sprockets inside the assembly.
I used SolidWorks 2011/12 Student Version as supplied by Oklahoma Christian University to all of their students.
-Rion
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
