Re: What Language To Use?
) I have nothing against people who have programmed in any language, as taking up a language shows they are interested in programming and computers, which, IMHO, is more important than previous knowledge. |
Is the team bad, or just their designs, or both? Or is it a case where the design is great, but just for a different game? Or is it a reliability problem? Or...?
You can't fix everything in software, but some rational and logical suggestions might be able to turn bad into good. How can we help? |
Our SVN repository has our CAD files in it as well as all the code. SVN works for CAD files as well.
For reference, Git works as well. Use whatever works best for your team. |
Don't do this. You can (and definitely should, if you have time and are considering multiple languages) do it during the off season to get a hang of each language and play around with which one is better/easier to code with, but if you do this during build season, you will not end up using better code. You'll end up using code that only has half the time put into it that it could have had, which usually implies it's not as great as what it could have been.
Unless the programmers know enough to write code in C++ and Labview and use each environments components interchangeably in the code that is used on the robot (highly unlikely), developing on both platforms means time is lost that could have been spent improving upon only one platforms existing code. The exception occurs only when you have several programmers who are only fluent in one language, in which case, yes, it might be a good choice to split them up, although productivity-wise, it would make more sense to have them retrained in c++/labView, so everyone is using a single language and the entire programming team can actually work together, rather than having several teams not working together. |
In team 67's case, they had two independent groups programming (no common programmers). They had so many people interested in programming that a single team would have been too large to be reasonably productive (I fully agree with this opinion - Too many programmers on a project of this size is a bad thing).
I talked with 67's lead LV programmer from that year. After talking with him, about LabVIEW, he made no mention of any interaction with the C++ guys at all. |
#10
In 2010, we started off using Java. However, we wanted to use the camera tracking code, and somewhere in the native libraries or WPILibj, it was crashing (I recall getting some sort of error in Netbeans's debug console).
Therefore, early on, we switched to LabVIEW. This worked great, until the end of build season, at which point... -- the camera stopped working again (after updating the cRIO image). We also experienced issues with code downloads (the only available workaround was to reimage before every download). As our code that year was relatively simple (because the default vision worked out of the box), it was within our capabilities to have coded in both languages (and C++ too, for that matter). Had we done so, we could've switched languages away from LabVIEW -- likely solving the code download issue (since Java and C++ use FTP, and LabVIEW doesn't AFAIK) as well as possibly restoring camera function. I am considering writing code in multiple languages this year -- even if we only get vision (assuming it exists in the next game) working in one or two languages, it'll still be driveable should we encounter a killer bug in one of the cRIO's images. Of course, this means nothing if you don't have programming time to spare -- after choosing a "main" language, don't sacrifice the quality or performance of your main code just to work on the backups. Just my 2¢. |
#11
Here is my two cents: do not get caught up in the whole "which" language debate in the first place. Just pick one. The language you use will not affect performance of the robot (unless you are doing some memory intensive calculations and need to optimize). What is important is the way you think and come up with a solution. Regardless of the language, the solution is the most important thing here. Different languages will not hinder your ability to come up with that solution; chances are, you won't be using features specific to one language. For example, pointers; every object other than primitives in Java are essentially pointers. Don't be immature and say "oh, but I want to use pointers, so I must use C++". No. You also probably will not need inline assembly either. Java just makes memory management easier too. If your java program has a memory leak, you are doing something very wrong...
#13
If there is any question about which programming language to use, I would follow Don's advice and stick with C++, Java, or Labview.
You will find that if you encounter any problems, there will always be a mentor or student on another team nearby that can help you with any of those three. If you go with Python, your choices for assistance will be far more limited. Python is fun for the off-season, but I would always stick to an officially supported language for the competition, because the libraries for the officially supported languages have been heavily tested and you get the support of other teams. |
#14
I want to know why people keep saying that python is sketchy and shouldn't be a first choice of language. It's not as if the motors will suddenly stop working, is it (assuming it's properly programmed and tested)?
#15
Because it's not officially supported (so WPI/FIRST/NI can't help you) and very few teams use it (compared to LV, C++, and Java), so you have less community help.
