Go to Post I realize that I've been drawn into the trap of thinking that this is about robots and scores and winning. Reboot. Remember why we do what we do. - Mr. Van [more]
Unread 14-10-2011, 18:41
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
Rookie Year: 2010
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
WPILib CAN Communications
Does WPILib support both the RS-232 (Black Jag Gateway) and ethernet (2CAN) style CAN networks? I can't tell from the CANJaguar class if it only supports one of these modes or both. If it does support both modes how does it detect which you are using?
Thanks
Joe
Unread 14-10-2011, 19:46
rrossbach rrossbach is offline
AKA: Ron R
FRC #2607 (RoboVikings)
rrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to behold
Re: WPILib CAN Communications
WPILib supports both, there is no difference in the robot code or WPILib code between the two.
The difference is handled by the plugin on the cRIO - if you're using RS-232 you run the Black Jag plugin on the cRIO, if using 2CAN you use the 2CAN plugin. The cRIO imaging tool lets you select which to use, or you can edit the ni-rt.ini file yourself to load the plugin you want.
FIRST Mid-Atlantic Volunteer
FRC Team #2607 Mentor
Unread 15-10-2011, 09:01
Rookie Year: 2010
perfect thanks!
Unread 24-10-2011, 13:27
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
Note that (I believe) you can only use one or the other, you cannot use both.
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Unread 24-10-2011, 14:33
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
That is correct. You chose which interface by selecting which to load. If you load both, the second one loaded will replace the first one.
-Joe
