Go to Post I know nothing. - Erin Rapacki [more]
Unread 19-10-2011, 16:39
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Detecting rectangles with the camera and Java
I'm a programmer for my team and I'm working on autonomous during the offseason, but for it to work properly, the robot has to be parallel with the sides of the field. I was thinking of aligning the robot to face the plexi sheet in front of the drivers' area, but I really have no idea how to make the robot actually recognize that rectangle. Help would be greatly appreciated.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 20-12-2011, 22:38
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
Rookie Year: 2012
shuhao is an unknown quantity at this point
Re: Detecting rectangles with the camera and Java
Apply an edge finding (both vertical and horizontal) algorithm. Try to scale your image down first (< 100x100) and take the grey scale for optimization.
Try the simplistic kernel of
Code:
1 -1
for horizontal edge and
Code:
for vertical edge,
I assume that your "rectangle" will look like
Code:
as it seems to be on the ground, so go through your filtered image and try to recognize those pattern with something like a machine learning algorithm
Either way, it's pretty tough...
