Go to Post Here's some food for thought: Does your FRC program need the students, or do the students need your FRC program? - sanddrag [more]
Unread 20-10-2011, 02:28
Spirator Spirator is offline
AKA: Munaum Muhammad
FRC #3132 (The Thunder Down Under)
Rookie Year: 2010
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
Alternatives to Pinion and Spur Gears
Hi,
I'm making a CAD for a Logomtion roller gripper and I'm stuck at the power transmission stage.
At the present moment, I have an RS395, a pinion gear and a spur gear driving a 0.5 inch hex shaft. My issue with this is that pinion gears and spur gears are hard to source.
Is there any alternative to this? I've attached a picture of the current design.
I've considered polycord, but the joining kit costs $1200 here and we don't want to spend that much.
Unread 20-10-2011, 02:34
AustinSchuh AustinSchuh is offline
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
Re: Alternatives to Pinion and Spur Gears
We have been able to join polycord pretty nicely with a bunson burner (had one lying around) heating up a big steel sprocket to melt the ends. Net cost to us, $0.00.
Also, your roller is probably spinning way too fast. Worth checking and comparing. 971's has something like a 25 to 1, or a 16 to 1 gear reduction, and I wouldn't speed that up more than 2x if at all. Check the surface speed of your roller. It probably shouldn't be much more than the speed of the robot.
Unread 20-10-2011, 02:37
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Friction rollers could be a poor man's geartrain (the slippage could even be an asset). There's always chain too (maybe plastic chain, because it's a bit easier to deal with than metal in small sizes). Vex parts, if available, offer a lot of options as well.
If you want to weld polycord, though, you can do it with an open flame, or a hot plate and some ingenuity. The kit is fine, but not necessary for most small jobs.
See here for more ideas.
Unread 20-10-2011, 03:37
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
The urethane belt joining kit is not worth the cost. You can make your own clamping and joining jig for little to no cost, and use something like a "Hot Knife for Her" from your local Michael's crafts store to melt the ends.
You can also use timing belts.
On the gear reduction, you probably do want something up around 16:1 or slightly more.
Unread 20-10-2011, 06:32
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
You should definitely fit a small gearbox to the motor, and I think you can get away with friction wheels - it probably will only slip when the tubes are fully acquired, which is ideal.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 20-10-2011, 07:50
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
You can get hollow urethane belting from McMaster-Carr that uses metal barbs to join the ends if you don't want to weld your own polycord. We have used it a few times over the past couple seasons. Just be sure you cut the ends of the belts as straight as possible and the barb won't come out.
Unread 20-10-2011, 08:23
Chris Hibner's Avatar Unsung FIRST Hero
Chris Hibner Chris Hibner is offline
Eschewing Obfuscation Since 1990
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Chris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond repute
We've used a lot of polycord over the years and have never had the joining kit. We join the ends using a standard lighter that you can buy at a gas station for $1, then just let the person with the steadiest hands hold it together until it hardens. We've never had a problem - polycord is ver flexible and doesn't need to be perfect.
One of the biggest reasons we would use polycord in your design is for weight distribution. Using the polycord can allow you to move the motor further from the tip of the arm.
An ounce of perception is worth a pound of obscure.
Unread 20-10-2011, 09:36
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
Rookie Year: 1996
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
We've always used an old soldering iron for our polycord.....we ground the sides more or less flat and used it as a knife between the edges....then just join by hand.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 20-10-2011, 13:31
roystur44's Avatar
roystur44 roystur44 is offline
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
roystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond repute
Send a message via Yahoo to roystur44
Take a look here. This supplier is the place to go for transmission products.
http://www.sdp-si.com/eStore/CoverPg...Components.htm
Roy
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 20-10-2011, 15:25
Peter Matteson's Avatar
Peter Matteson Peter Matteson is offline
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Peter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond repute
Here is a shot of our prototype from this year that was made from less than $200 total materials including transmissions, polycord belting (fused with a grill lighter), spockets, #25 chain, and Al hex, plate, and round stock.
http://www.chiefdelphi.com/media/photos/37060
We made 5 iterations out of Rought $200 worth of raw materials including the final one shown here:
http://www.chiefdelphi.com/media/photos/37063
The powertrain is banbots RS-545s through banebots planetery transmissions, then a 1:1 driving the rear rollers and the polybelting driving the front rollers.
This is a simple design that looks fancy only because of the machining. We had a wood prototype week 1 of build to test out the dimensions for claw before cutting metal.
2011 Championship Finalists/Archimedes Division Championships w/ 2016 & 781
2010 Championship Winners/Newton Division Champions
Thank-you 294 & 67
2009 Newton Division Champions w/ 1507 & 121
2008 Archimedes Division Champions w/ 1124 & 1024
2007 Championship Winners/Newton Division Champions w/190, 987 & 177 The Wall of Maroon
2006 Galileo Division Champions w/ 1126 & 201
www.bobcatrobotics.org
"If you can't do it with brains, it won't be done with hours." - Clarence "Kelly" Johnson
Unread 20-10-2011, 15:35
Bob Steele's Avatar
Bob Steele Bob Steele is offline
On the RIBMEATS bandwagon....
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
#25 chain and sprocket... use aluminum sprockets from AndyMark
Pretty light... easy to service... just watch the RPM's
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 20-10-2011, 19:23
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
I'm not sure if some of the people in here realized you were from Australia and shipping from the US is quite difficult, so some suppliers like AM and McMaster might be out of the question for you.
I was able to find one Australian Company that might be a good supplier for things like chains and belts. http://www.smallparts.com.au/ Seems like they carry a lot of the things suggested in this thread.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
