Go to Post My mom's cousin heard from her friend who heard from her brother who heard from his barber who heard from his son that his teacher told him that his father's brother's sister's former roommate heard from Frank himself. - notmattlythgoe [more]
Unread 21-10-2011, 00:24
maddoctor90's Avatar
maddoctor90 maddoctor90 is offline
AKA: Matt
FRC #2481 (Roboteers)
Rookie Year: 2007
maddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to behold
Bluetooth At Events
Our team is looking in to creating some type of electronic scouting method for use at events. I am aware that in the past teams could not set up WIFI networks and were not suppose to arrange for internet access. Because of these restrictions, I was wondering if anyone could tell me if Bluetooth was restricted as well. The only thing I can find from last years rules is section 4.4.1 which states:
4.4.1 Robot Wireless Control
 Robots may be operated via wireless control only on the competition fields and the practice field with the FIRST supplied radio; and
 Teams are not allowed to set up their own 802.11a/b/g/n (2.4GHz or 5GHz) wireless communication (access points or ad-hoc networks) in the venue
Unread 21-10-2011, 01:07
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Bluetooth At Events
Your best bet is using some hosted server and 3G or 4G smartphones for web access.
Unread 21-10-2011, 02:11
mesamb1's Avatar
mesamb1 mesamb1 is offline
AKA: Sam Bacon
FRC #1466 (Webb Robotics)
mesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nice
<R79> Other than the system provided by the ARENA, no other form of wireless communications shall be used to communicate to, from or within the OPERATOR CONSOLE
Examples of prohibited wireless systems include, but are not limited to, active wireless network cards and Bluetooth devices.
If your trying to set up the network with tablets(because they have bluetooth, wifi but not 3g) then I would set up bluetooth and just step out side of the arena to sync your scouting data. If you need real time both of the other suggestions were tried by our team and were highly successful.
Unread 21-10-2011, 02:36
EricH's Avatar
Happy Birthday! EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
You'll notice that that rule you quoted (<R97>) is in the Robot section of the Game Manual, while the 4.4.1 rule that the OP posted is from the At the Events section of the Administrative Manual. While this does not preclude the rule from consideration altogether, it does diminish its usefulness in preventing Bluetooth networking. <R97> is intended for Operator Console communication, internal and external.
That said, I would encourage development of a system that doesn't use Bluetooth; it may be possible that FIRST develops a game component that uses that band, in which case they would take measures to ban it. (Note that NXTs on Minibots had to have their Bluetooth disabled.)
One old classic method is to have paper reports go to a computer in the stands for entry. No wireless needed, and no wires needed either (except to keep the computer running).
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 21-10-2011, 02:58
mesamb1's Avatar
AKA: Sam Bacon
My mistake EricH,
However further investigation on wikipedia/bing reveals that bluetooth sends data on the 2.4 GHz bandwidth. Still, OP, you should post this on the FIRST forums for a GDC member to answer with an official verdict because there is some gray area
Unread 21-10-2011, 03:42
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
My mistake EricH,
The practical answer is that firstly, the Q&A is inactive between seasons so no ruling will be forthcoming (until the next set of rules are in force), and secondly, the rule is clear as is, so interpretation isn't really needed. There's no interpretation of "802.11a/b/g/n (2.4GHz or 5GHz) wireless communication (access points or ad-hoc networks)" that includes Bluetooth.
Legalistically, the robot rules only really make sense if they apply strictly to the robot (and its control system)—so unless FIRST says otherwise, don't worry about <R79> unless your controls are configured to speak Bluetooth. And even if you could get an answer, the Q&A is supposed to clarify rather than add new things to rules—so unless FIRST changes that for 2012, expect that an official will give you the benefit of the doubt if you're clearly following the rules, even despite a Q&A response to the contrary.
The technical answer follows from references like these: HP, Cisco, a trade magazine.
Originally Posted by HP
Both Wi-Fi and Bluetooth fail gracefully in the presence of interference. By this is meant that the communication protocols are very robust and include mechanisms for error checking and correcting, as well as requesting that corrupted packets be resent. Therefore the result of increasing levels of interference is almost always confined to a slowing of the data rate as more packets need to be resent. Only in extreme conditions, such as setting a Bluetooth-enabled cell phone down next to an operating microwave oven, is it likely that communications will cease altogether.
Unread 21-10-2011, 09:38
DonRotolo's Avatar
Back to humble
FRC #0832
Your question is about Bluetooth. The only good answer is that we won't know until the 2012 rules come out. But maybe.
Last year we were unable to to get permission to establish a local (not connected to Internet) wifi network for our scouting server, so we just used wires. The router/switch/hub runs on 12 Volts DC and operated the whole day on a single robot battery. The scouts sit near each other anyway, so it wasn't a burden.
At CMP we didn't have AC in the bleachers, so we used a 12V-110V inverter and a specially-prepared (for safety) marine deep-cycle battery to run the printer and 'emergency' laptop chargers; laptop batteries were charged in the pit, and the server was another laptop.
Unread 21-10-2011, 13:00
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Team Role: Teacher
Rookie Year: 2007
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Last time I was at a regional I looked at the sheer number of bluetooth devices transmitting and it was over a hundred. I suspect many people don't know how or simply neglect to turn off the functionality when they don't need it. We saw everything from Wii motes that people were using for scouting to people's laptops and phones. Given you have to pair with device names that might make things a bit interesting especially if you get dropped and have to rebuild your network.
On a side note, what wattage inverter did you use Don?
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 21-10-2011, 20:12
AKA: Matt
Rookie Year: 2007
Thanks for all of the input! We were hoping on using Bluetooth so that we could use tablets and not have 3g service on them. I like the idea of using LAN with a switch, but that would mean we would need to move to some type of computer. Right now we are still in the planning stages, I really do not want to spend a lot of time designing a system that we won't be able to use. I like the idea of creating a Bluetooth sync, where we could just step out and sync data between the devices if Bluetooth is indeed banned, because we could just use that as a backup if the need arises.
Unread 22-10-2011, 00:55
ratdude747's Avatar
ratdude747 ratdude747 is offline
Official Scorekeeper
AKA: Larry Bolan
ratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond repute
I know at events (st. louis included), I used my lapop's bluetooth chip and my cell phone's 3g in the pits to download a file from my email inbox for a slideshow to play in the pits.
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010, 2783 Engineers of Tomorrow 2011, Event Volunteer 2012-current
DISCLAIMER: Any opinions/comments posted are solely my personal opinion and does not reflect the views/opinions of FIRST, IndianaFIRST, or any other organization.
Unread 23-10-2011, 23:01
Michael Hill's Avatar
Michael Hill Michael Hill is offline
FRC #3138 (Innovators Robotics)
Michael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond repute
The rules last year specifically disallowed wireless communications categorized as IEEE 802.11 a/b/g/n.
Bluetooth is classified as IEEE 802.15.
You should be good (assuming the rules do not change).
Unread 24-10-2011, 09:52
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Matt,
If you look at Bluetooth specifications you will find that it is intended for one master and up to seven slaves with typical distances of less than 10 meters. If this meets your requirements, then there doesn't seem to be anything in the 2011 rules that would prevent it's use.
Al
WB9UVJ
www.wildstang.org
________________________
