Thread Tools |
Rating:
Display Modes |
ftp to crio
I thought I had saved instructions, how to FTP to the crio, but i can't find them. Can anyone give me some help in looking at the files in the crio?
thanks wendy holladay |
Re: ftp to crio
Go the windows start menu and then click on "run". Or press the windows key and "R" at the same time.
Type CMD and press enter. Type FTP 10.XX.XX.2 where XX.XX is your team number and press enter. There is no default log in and password. Press enter twice. You're now browsing in the cRio. If you need to use a windows-gui interface ftp client, simply set it up to ftp to the above address with anonymous login and password. |
Re: ftp to crio
To expand:
use the put command to post a file : put file.txt use the get command to retrieve a file: use cd to change directory use dir to list the directory use ! infront of a command to have it run on your machine (!dir lists your machines files) Most of the stuff you will be looking for or using is in /ni-rt/ |
Re: ftp to crio
got it working
thanks |
